FH12-D12D-420 Crankcase Pressure Problem
Discussion in 'Volvo Forum' started by Amushonga2000, Mar 19, 2014.
  1. Amushonga2000
    Amushonga2000 Bobtail Member
    Truck starts and runs well but when sufficiently warmed up, crankcase sensor reports and shuts down the engine. I have had the truck serviced recently and changed the crankcase sensor and the oil pressure sensor - no change. What are the possible causes, any pointers?
  3. bad-luck
    bad-luck Road Train Member
    3,264
    5,983
    Nov 16, 2013
    Baltimore, Maryland
    How many miles? It could possibly be excessive blow by.
  4. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Is there a crank case filter on the truck if they get full of oil it will turn on check engine light
  5. Amushonga2000
    Mileage is about 500000 miles
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    first of all check crancase vent tubes, if they are ok I sugest bad crankcase sensor ore bad wiring. Usually bad sensor, spring inside it goes weak and it reads more pressure.
    really U can disconnect this sensor and ignore fault code, but if crankcase vent is clogged u may get valve cover blown)))
    Amushonga2000 Thanks this.
  7. Amushonga2000
    Will check wiring - replaced oil pressure sensor, crankcase sensor, put in new oil pump, checked bearings as well. It has to be an electrical fault, it's reporting crankcase pressure, oil pressure and lack of oil. Will have harness checked. Thanks Pablo.
