fifth wheel grease removal advice
Discussion in 'Experienced Truckers' Advice' started by Mrredek, Aug 12, 2015.
  1. Mrredek
    Mrredek Bobtail Member
    15
    6
    Apr 19, 2014
    So on a very frustrating morning, I forgot to remove my air and power lines from a trailer I was unhooking from. Needless to say, I ripped my lines put when I pulled away. In doing so I ran the lines along the fifth wheel, and caked them in grease. My lines are not damaged. I have tried soap and water with rags, but that seems to spread the grease around. Anything else I can try?
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Take some "sandy dirt" or perhaps some sort of smaller grain cat litter and some gloves and "scrub" the lines with this. They sell an aerosol "de-greaser" available at most places but these typically have minimal benefit. Regardless, afterward you will probably need to utilize a high-pressure car wash hose to remove the residual mess.
    Mrredek and Cottonmouth85 Thank this.
  4. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Gasoline, you can't was that stuff off.
    Poacher, unholy7 and Mrredek Thank this.
  5. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    i have used Brake Kleen, it is a good degreaser. i would recommend that you spray the Brake Kleen onto a rag, for better coverage, as that stuff costs big money, and /or then you can use Purple Power, if you can find that in a spray bottle. nearly any degreaser you can buy at an auto parts store, or even at the truck stops.
    use disposable rags that come in a roll, much like paper towels do, use the rags to wipe off, if you use a spray bottle, otherwise, soak the rag in the stuff, if you're buying it by the gallon. then of course, properly dispose of the rags.
    you ain't the first person this has ever happened to.
    good luck.
    Big Don, Dreamboat, Mrredek and 2 others Thank this.
  6. Mrredek
    15
    6
    Apr 19, 2014
    I appreciate the reply. I tried dish soap, but not a full fledged degreaser. Will get some next time I am at the store.
  7. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    nearly all dish soaps have degreasers, but not nearly enough as the HD stuff. the dish soap will however, remove wax from your car.
    Big Don and Mrredek Thank this.
  8. tucker
    tucker Road Train Member
    12,647
    40,424
    Jun 13, 2008
    IN
    Soak a rag with engine oil, it should remove the grease, then a citrus spray to remove the oil.
    blairandgretchen and Mrredek Thank this.
  9. Lyle H
    Lyle H Road Train Member
    1,291
    2,941
    Apr 16, 2014
    WD-40 works good too.
    RedForeman and Mrredek Thank this.
  10. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    i suppose he could always go into a truck parked at the fuel island, and grab that driver's clothing. i hear wayward parked truckers clothing, makes for great rags.
    Dreamboat Thanks this.
  11. Vintage
    Vintage Light Load Member
    142
    119
    Mar 16, 2013
    Sea to Shining Sea
    If you can get a hold of some dettol that stuff works on almost anything
