Fifth wheel height and overweight on drives
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 77fib77, May 4, 2017.
  1. 77fib77
    77fib77 Road Train Member
    10,468
    65,418
    Jul 7, 2010
    St Louis
    I got pulled in the scale house this morning. I was 1000 pounds over on the drives. 47.5" is the fifth wheel with trailer. The kingpin is in the middle of the tires. 1/2 tank of fuel 3/4 def. Company truck. He gave me a warning and level 2 inspection, which was clean. Fifth wheel to low?
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Looks like fifth wheel needs forward
  4. 77fib77
    10,468
    65,418
    Jul 7, 2010
    St Louis
    That would be the easiest.
  5. Dave_in_AZ
    383,723
    Can't you slide tandems?
    Bakerman Thanks this.
  6. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Yup. Move 1000# up onto the steer and your problem is solved.
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    I was assuming the OP pulls a tanker, as a liquid product is the only thing that would be affected by 5th wheel height. Most tankers don't have sliding tandems. The solution here is simply to move the 5th wheel forward...has room for 1260# and only needs to lose 1040# from the drives.
    IF the tandems can be slid, he could move them as well to balance the load that way...but that doesn't change the fact that the 5th wheel is too far back and he'll never get 80,000# legal where he's got it. If it is a liquid tank, he may look into a small riser or slightly taller 5th wheel plate in addition to moving it forward, so that the load is balanced better between the drives and trailer...needs about 1000# or so shifted backwards, too, to fully balance the load.
  8. 77fib77
    10,468
    65,418
    Jul 7, 2010
    St Louis
    You know I feel dumb. I haven't played with sliding anything for about three years. Yes steers are light. Just move forward the king pin. I got fixated on fifth wheel height.
  9. 77fib77
    10,468
    65,418
    Jul 7, 2010
    St Louis
    Yes im pulling a tank
  10. V c2c
    V c2c Light Load Member
    218
    176
    Aug 16, 2016
    Waco Texas
    Ya just slide it forward 2 notches and should be good
  11. danmirza
    danmirza Bobtail Member
    8
    4
    Apr 3, 2017
    17 k max per axel if is a tandem. Maybe something else is wrong. IN,IL,GA they love split tandem weight
