Fifth wheel lock CLOSES prematurely before hooking up!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ichudov, Aug 9, 2019.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    I have a Fontaine fifth wheel. I notice that it CLOSES occasionally before it even engages the king pin.
    This makes the truck look as if it is hooked up whereas it is not at all hooked up. I do check fifth wheel engagement, of course, and I know that it is wrong. I open the fifth wheel and then I can engage properly the second time.
    I think that it closes prematurely due to being shaken like when it is goes under the truck. I understand that I neds to be fixed, any idea how?
    KB3MMX Thanks this.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yes replace it!!!
    That's an accident waiting to happen.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    Get a rebuild kit and jump on YouTube. Every manufacturer has a video on how to rebuild. It's very easy
    Big_D409, Owl sharpton and mhyn Thank this.
  5. motocross25
    motocross25 Road Train Member
    3,841
    11,649
    Sep 23, 2010
    Overland Park, KS
    I’m not in anyway trying to be a smart ###, or trying to tell you how to do things, but you’re on to something with the trailer shaking before hooking. It could be as simple as that. I’ve blasted under trailers dropped too low and had the fifth wheel jaws clamp before latching the pin. If a trailer is too low dump your air, get under it then lift it up and hook. But if this is not the case, then yea absolutely get that replaced. That’s an accident waiting to happen with the best outcome being that trailer sliding off in the parking lot and not the highway.
  6. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    What rebuild kit do I need. Full rebuild kit? Or just the jaws and spring? Fontaine 7000 5th wheel.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,466
    6,504
    Aug 26, 2014
    There is a kit with three springs that go under the plate. I do not remember which one of the three but if it breaks the 5th wheel will do that. Look at other 5th wheels and see if you have all the same springs. It maybe faster to unpin the plate and flip it over for installation.
    They are like a screen door spring not a rolled up coil.
    ichudov, spsauerland and Oxbow Thank this.
  8. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    @BoxCarKidd I agree and I am sure that it is the spring that holds the release trigger down. Or whatever it is called. I spent some time learnings about that stuff.
    I bought a rebuild kit for $206 and I will rebuild this 5th wheel.
    Oxbow, MartinFromBC and Owl sharpton Thank this.
  9. BoxCarKidd
    4,466
    6,504
    Aug 26, 2014
    I repaired two in the last year. About $30 dollars worth of springs. I replaced one with the plate on but got frustrated and flipped the plate over on the second. They may have been different heights?
    Oxbow, swaan, ichudov and 1 other person Thank this.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,854
    Sep 16, 2015
    Ontario, Canada
    I bought a couple trucks had Fontaine wheels on them. They had 3500 series Hollands on them before they ever left my yard.
    Oxbow and spsauerland Thank this.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have had fontaines on several trucks, and had zero problems with them. I Have one on my truck now, but I need a taller fifth wheel and just bought the new style slider with taller perches off a new pete, so will be getting a new holland to put on it.
