fifth wheel not slanting
Discussion in 'Kenworth Forum' started by Highwolf89, Sep 27, 2014.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    I am having problems with my fifth wheel and it makes it hard to hook up to some trailers especially sense I have 24.5 tires. My fifth wheel after uncoupling it does not go back down at a slant but stays parallel to the frame. Just as if I was hooked up to a trailer. I tried jumping on it to try to make it go back to an angle. I have tried spraying some BP on it. Just dont know how to get it back to normal. I bought the truck like this by the way. Any ideas what I may do. I pulled a RGN the other day and very difficult to hook up because of this issue. I know I can get ramps looking into it, but I know they say you still need your fifth wheel to slant for them to work properly cause if to high it can cause drag on turning of the trailer and such..
    Thank You
  3. wore out
    wore out Numbered Classic
    15,845
    191,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Are you sure its not blocked solid. This is done when pulling a frameless end dump. If it is then its not pivoting properly when pulling a normal trailer that ain't good
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    8ft. 2*4 or 4by4 will make it move if not CK. the ft. of 5th. wheel for a shim or rod like wore/out said, need to look for grease fittings under 5th wheel plate to grease the bushings if not found may need to have bushing replaced at 5th wheel shop, look for name of man. that built it on FT. or side of plate then look up nearest shop?
  5. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    yep, either it was pulling a dump type trailer and the 5th wheel is locked in with a rod of some sort to which should be able to be removed. or the bushings have never been greased and now it's frozen in position.
  6. Highwolf89
    294
    61
    Jul 30, 2013
    I will have to check for the rod I believe the guy said it pulled a concrete bulk tanks... If the bushings are frozen is there a way to get them in frozen??
  7. Joed2323
    Joed2323 Bobtail Member
    9
    Sep 30, 2014
    If the bushings are frozen id recommend replacing the bushings, depending on what type of fifth wheel you have
  8. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    New style Holland 5th wheels don't have grease nipple anywhere.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Aren't they greased thru the top when you apply grease to fifth wheel on the slots on outer edges if I'm thinking on same fifth wheel
  10. Pipe 40
    Pipe 40 Light Load Member
    209
    359
    Mar 24, 2012
    Toowoomba Queensland
    Jost fifth wheels don't slant when unhitched because of the way they are bushed
  11. rollin coal
    rollin coal Road Train Member
    13,267
    26,725
    Mar 29, 2008
    TN
    You sure about that? Mine does and has ever since installed.
