Fifth Wheel vers Ball/ Hitch
Discussion in 'Questions From New Drivers' started by sal, Sep 15, 2007.
  1. sal
    sal Medium Load Member
    517
    138
    Aug 18, 2007
    sacramento Ca
    Have pulled a 40' flatbed trailer across the states a few times( it was the ball/ hitch type ). How much difference is a fifth wheel type to pull? Are they better handling and maneuver better ? I've never pulled a fifth wheel and was just wondering what the difference was. Thanks
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Your biggest differance will be your pivot point and this will affect backing to begin with. And the fact that you will now get to see the trailer in you side window "first" if you jack knife ;)
    Of course, if you are doing this with a pick-up/dually. It now places the trailer at a level that can remove the top of the cab, and it's contents (read: your head) with ease in the event of a jack knife. Learn to duck fast.
    A ball and hitch back the same way to me, just faster. But depending on the trailer tongue design and length of trailer, I might put it into the frame/bed before I realize it.
  4. Burky
    Burky Road Train Member
    In general, a 5th wheel type of hitch will be a little bit more stable than a ball hitch type. The hitch point is directly over the axle, so there is less opportunity for the hitch to develop any sway by rocking the last 5-6 foot of the truck from side to side. They back basically the same, and if you have the skills to back one, you'll have no real problems with the other. Biggest thing is make sure the trailer is loaded correctly, and has enough, but not too much weight on the hitch point. Most trailers you see that are a bear to handle are not loaded right, and sway because of it.
