So how do you guys find center of your flatbed? I know generally speaking the signal light in the middle of a 48' but if I were to measure would I measure from kingpin to center of spreads or from kingpin to end of trailer and divide that number?
Finding center of flatbed.
Discussion in 'Questions From New Drivers' started by allen731, Sep 4, 2016.
Knighthawk3 Thanks this.
Im Talking about for center loading for weight distribution.
It will vary based on the load, center is pointless when the load is not balanced front to back. A machine will be placed differently than 40' pipe, or 20 bundles of pipe that range in weight from 1200lbs to 2400... then is it tandem or 10'2 spread? And so on... go over to the flatbed forum and poke around, lots of experienced hands in there
The center point is really critical when hauling a single 48K roll of steel. Inches in either direction will throw you off by thousands of pounds. More experienced hands can explain this FAR better than I can.x1Heavy, MJ1657, TripleSix and 1 other person Thank this. -
Misunderstood, what lepton said -
Trailer tandem and fifth wheel placement will have an effect on this as well.
One suggestion could be to keep both slid back, so the ends of the trailer are in roughly the same position relative to the axles. That way, you can go with the center of the trailer when loading and adjust things as needed afterwards.Lepton1 Thanks this. -
Take the 5th wheel placement out of the equation. It doesn't change the kingpin setting on the trailer, and therefore does not change the center of the trailer measurements as brought out by Mr Lepton.
there is a center of a FB trailer, I've seen the truck co. (maybe it was the manufacturer) mark it, like load 50K coil here. But, remember, hooking that trailer to a 300" wheelbase power VS. a short daycab will make a difference in weight distribution.
I never like moving 5th wheel but if I have to move it, I'll roll up the sleeves and get it.Lepton1 Thanks this.
