Fire!
Discussion in 'Trucking Accidents' started by Noggin, Jan 21, 2013.
  1. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Raiderfanatic Thanks this.
  3. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    Wonder what the story was on this one. Sounds like the driver wasn't injured at least.
  4. secretariat
    secretariat Bobtail Member
    34
    15
    Oct 9, 2012
    we had a couple of trailers burn up a warehouse i worked at, didn't take em long, later it was said someone had flicked a cigarette in one of em. i can understand the trailers cause of all the wood flooring and walls in them but that truck... wow! that sucker burned to the ground, guess i never thought of the things inside and out that could've added to that burning. probably had a full tanks and i'm sure that trailer went all the way to; soon as i reached that tank.
    NavigatorWife Thanks this.
  5. Homemade1959
    Homemade1959 Light Load Member
    130
    47
    Jan 21, 2012
    any of the 48 states
    WOW :biggrin_25524: where was the fire department? I wonder if it was caused by an inverter. I've heard those power inverterscan torch a truck if they aren't done right. hope everyone was okay.
  6. chemsoldier1
    chemsoldier1 Medium Load Member
    458
    210
    Apr 10, 2011
    Lufkin, TX
    The "Big Radios" can cause truck fires also. The construction company I worked for prior to doing mega carrier dry van lost a truck that way. Any time you have to run a bunch of wiring to battery terminals you run a risk of fire. You also have the problem of extra heat generated with all components of over powered radios. Many drivers just don't seem to understand these things.
    As far as cigarettes in the trailer goes, if tossed cigarettes can cause that kind of inferno then I guess conditions must have been just right. I've actually pulled off of docks before after lumpers have been at work and found tons of cigarette butts in the trailer that I had to clean out when I swept. Never had a fire yet though.
    BossOutlaw88 and TRKRSHONEY Thank this.
  7. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Nothing better than "stupid truck driver" commentary via the child's band radio.
  8. 48Packard
    48Packard Ol' Two-stop Shag!
    8,409
    10,072
    Apr 19, 2009
    Could be anywhere
    Any time I see one of these tractors burning it sends chills down my spine.
    CondoCruiser Thanks this.
  9. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    If the wires are properly sized, connected and fused there is no more danger of fire than any other electrical device.
  10. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    But,
    he saved $$$$ by cooking his own Ramen Noodles..........:biggrin_2559:
  11. thunder kw
    thunder kw Bobtail Member
    23
    Dec 5, 2012
    did he say dam mexican fuse boxxes??
