firestik nogroundpane antenna as base station stealth specops antenna?
Discussion in 'CB Radio Forum' started by seebeereedio, Feb 1, 2023.
  1. seebeereedio
    seebeereedio Bobtail Member
    10
    20
    Feb 1, 2023
    as the title so beautiful says in a lot of words, can i get a DX going with a little firestik on the roof of my house? i have a lincoln 2+ with 50 watts of am power.
  3. Ridgeline
    22,469
    117,831
  4. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    No reason you couldn't. A no ground plane antenna won't be as efficient as one that has a ground plane, but it should still work. If propagation is good you can DX with 5 watts and a coat hanger.
  5. seebeereedio
    10
    20
    Feb 1, 2023
    Well, i want it stealthy, not to alarm the neighbours
  6. seebeereedio
    10
    20
    Feb 1, 2023
    nice, thats what i wanted to hear!
  7. Ridgeline
    22,469
    117,831
    about what? You live in a communist commune called an HOA?
    TO answer the question, a NGP antenna uses the coax as a ground plane or an rf ground, which is why they don't work well outside of a boat or car, many times they are just a stop gap measure to get to use the radio.
  8. Terlingua
    487
    1,019
    Oct 24, 2021
    You would certainly get better performance attaching a few 1/4 wave radials, which would be about 9ft for CB frequencies, and laying them out across the roof.
  9. seebeereedio
    10
    20
    Feb 1, 2023
    you think i fry my radio with a no ground antenna? or just dont get the reach a normal one gets?
  10. seebeereedio
    10
    20
    Feb 1, 2023
    so dont use the firestik but get a radial? are they low profile?
  11. Ridgeline
    22,469
    117,831
    both
