So i drive a mack 18 speed eaton fuller tranny. Having a really hard time with the first 4 gears in the city. I can shift hi range gears no problem. The first 4 after start up is really messing up my take offs. The high gears wind up to about 1600rpm then shift smooth. Cant get the idea with the lower 4 gears. Any advice would help thanks. Im shifting around 1200 right now but i always miss a gear floating.
FIRST 4 GEARS
Discussion in 'Ask An Owner Operator' started by MackRookie, Jun 20, 2018.
Page 1 of 4
I also watched some mack videos they shift like #### i guess.
When I drove 18 speed I always skipped the even numbered gears in low range... You dont need them unless you are very heavy or pulling a good upgrade. I also shift the low range gears at a much lower rpm.
What exactly about the first 4 gears is hard for you? What happens when you try to shift? Does it not want to let go of the gear? Do you miss the next gear?
Edit: oh I see now you miss a gear... When you miss do you have to raise or lower the rpms to catch it?... In still thinking that if you are trying to grab all 18 gears in order you are using more gears than you need to... If this is the case maybe try shifting the lower range like you would a 9 speed (skip even numbered gears).Bean Jr. and MackRookie Thank this. -
In my experience you have to be really quick when shifting the lower gears in consecutive order... Can only think of a handful of times that I NEEDED to use all the lower gears, and they were all when loaded very heavy (100k +) while off road or pulling steep grades. Even if you dont let off the throttle much the rpms drop very quickly. Maybe try shifting at a slightly higher rpm.
MackRookie Thanks this. -
Il give that a go tomorrow i guess my pause in between the out and in is off
Do you know if that is okay for the tranny to skip gears
You can pretty much do whatever you want in terms of gear selection as long as you aren't lugging or over-revving the engine or grinding the transmission gears.
MackRookie, Cattleman84 and 06driver Thank this. -
So your saying i can start in 4th gear if im bob tail or empty?
Page 1 of 4
