First major expenses as an Owner Operator on the truck.
Discussion in 'Ask An Owner Operator' started by feldsforever, Sep 27, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Incudes engine oil change, one caliper. Four rotors. Four breaks. 4 Axle seals.
    Estimate is about 4100.
    Will post receipt of exact value when done.
  3. Dave_in_AZ
    315,770
    Where is the work being done? And that's just expense. Major expense is in the twenty large plus neighborhood.
  4. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Does two back to back expenses count.?? I'm getting 6 tires next week or the week after, all jokes aside how do I avoid a 15k plus expense?
    Mohtrucker, D.Tibbitt and Dave_in_AZ Thank this.
  5. feldsforever
    1,453
    1,440
    Nov 22, 2019
    T A. Ohio.
    Dave_in_AZ Thanks this.
  6. Dave_in_AZ
    315,770
    Good maintenance, and always keep in mind if you're easy on the truck, it tends to be easy on you.
  7. Dave_in_AZ
    315,770
    I would not even let a TA do that kind of job, especially in Ohio. Not kidding.
  8. Big Road Skateboard
    4,394
    20,915
    May 2, 2021
    Agreed x100000.
    Never, ever, ever...
    Change a tire yes, fuel filters maybe, adjust wheel bearing correctly and change a disc rotor, HELL NAH!
    Run, don't walk
  9. Dave_in_AZ
    315,770
    Patch a tire....... 5 hours. Then the kid tears the liner.
    Do not walk away.....RUN. Run like you are being chased by the alien.
    I've heard more horror stories about TA's in Ohio than all the rest combined.
  10. TheLoadOut
    TheLoadOut Road Train Member
    1,830
    8,247
    Nov 6, 2019
  11. Big Road Skateboard
    4,394
    20,915
    May 2, 2021
    I've got 26 years in as a mechanic, owning a very successful repair shop until I closed it in May.
    Stopped at a TA in Ohio, maybe Kentucky about two months ago for fuel filters and grease, check the boxes.
    Kid changes fuel filters, engine starts and dies. He asked me to keep cranking, and I asked if he filled the filters.
    "Of course", was his response.
    I cranked again for probably 15 seconds and told him to pull them back off. Filled them up. Voila!
    Then he told me he had to go get one of the "mechanics" to check my tranny.
    I told him nevermind. Pulled out and set the brakes, did it myself.
