first time driving spread axle flatbed
Discussion in 'Flatbed Trucking Forum' started by lazriel1988, Dec 26, 2014.
  1. lazriel1988
    lazriel1988 Bobtail Member
    17
    11
    Dec 18, 2014
    hey everyone i am about to start a new job driving a spread axle flatbed. i have only driven dry van and belly dumps before. i am just looking for any adivice yall might have for a rookie on what to expect with load securement and the differences of driving a spread axle compared to a normal tandem. thanks in advance guys and girls.
  3. Rugerfan
    Rugerfan Road Train Member
    7,134
    34,659
    May 3, 2011
    Redding,CA
    Don't take turns too tight with a spread axle. Try to avoid any 90 degree backing. It will drag the front axle and wear out your tires and sometimes if you get too tight it'll tear the tire off the rim. they are trickier to back but I haven't pulled anything but a spread for the past 2.5 years so once you get used to it it's simple
    ramblingman and n3ss Thank this.
  4. passingthru69
    Just follow Rugerfan's advice. Once you get used to the spread you will never want to go back to a closed tandem.
    Ride is better
    HauntedSchizo19 Thanks this.
  5. xsetra
    xsetra Road Train Member
    5,098
    6,952
    Aug 21, 2011
    Yep just what Rugerfan said. Don't turn very tight. You will flat spot your tires. Scrub/slide your front axle sideways instead of rolling your tires.
    Read your FMCSA handbook. That is a good start. Other than that watch the other drivers load. When in doubt put another chain or strap on your load. You're carrying that equipment anyway, put it on your load. Good luck.
  6. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Its not much different than a regular trailer.
    Often when backing, it can pivot on the front or rear axle, depending on where the weight is and if your on a 'hump' or not. Try to create as wide a swing as you can when backing to avoid dragging the front axle. If the axles slide and your doing legal loads, just keep the axles together. Once you get used to the trailer and understand where the weight will be, you will know before hand when to spread and when there is no need to spread. When spread they 'normally' like to pivot on the rear axle. Which is how I prefer it,.. some dont,.. but you have to keep in mind that the shorter the turn radius, forward or back, the more the front axle will drag or scuff the tread as I like to refer to it. Depending on the style of tires used,.. this can cause anything from pitting, to tearing in the tires.
    Get into the habit of checking those tires AND your load any time you make a stop. Hopefully you will get at least a basic run down before they send you out to get loads. Flat bed is totally different then anything in a box. Your load is out there for everyone to see. And as such its your responsibility to control how it gets loaded, how it gets secured, and how much finesse the load will need while going down the road. You will never see a flat bed driver sitting in his truck while getting loaded. There are no walls to catch load shift. If the load is not secure and it goes over,.. thats it,.. lost load or potential death for an innocent motorist. Secure your loads as if you family will be in the car behind you. Not only that,.. but think of your own safety as well. If you have to brake hard,.. make sure that load wont come crashing into the cab with you.
    I make it a habit to stop 20 - 30 mins after I get load,.. usually first rest area, truck stop or pull off I see where I can get at least 10ft away from traffic. Check binders/straps for looseness, make sure edge protectors will stay put and tarp will remain tight and not ballooning and blocking your rear view or flagging out into oncoming or other traffic or road side objects.
    Flatbed demands a whole new level of respect and attentiveness from you.
    Not trying to scare you. The level of self respect you will achieve once you become an old hand at this should make you feel invigorated. Dont be afraid to ask other drivers for advise or even help when getting loaded. Flatbedders arent like reefer or most van drivers,.. we will and do help each other. Lots and lots of tricks to the trade so to speak. Tossing straps, twisting to prevent flapping, hitching bungee on out of reach rings, laying out the tarps, Storing dunnage, using various objects to protect tarps and get loads level,.. way too much for me to list,.. and I dont even know them all. Still learning something new every time I go out. For me flatbedding is much more rewarding then anything else I have done. More work and yes,.. be prepared,.. you will have good days and you will have bad. Learn from your mistakes, dont be lazy and take shortcuts, do it right the first time.
    As with anything in trucking,.. time in the seat will make you a pro.
    Hurst
  7. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    My advice, if you think 6 straps will make it make it legal then use 10 or 12. I over secure everything. it is much better to spend a few more minutes securing the load than to have a claim or accident. And on the spread, see if you can talk you boss into a electric dump valve for either axle. Then when you have to turn short you can dump the air from one of the axle's and save some wear on your tires. Good luck.
  8. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    I guess Hurst beat me to it, and a much faster typer than me. But listen to him. He is right.
  9. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    agreed with all the above. were i am working now i have the abilith to dump the air out of the back axle. and it does make backing SO much easier
  10. Calregon
    Calregon Light Load Member
    170
    106
    Dec 8, 2013
    Oregon
    Where are you going to be working? You will get used to the spread. Just go slow take your time backing and turning. Where ever you work will more than likely go over and over and over securement. I have found this site to be helpful also. And have had several other drivers from other companies help me out. Dont be afraid to ask. One thing you can do is take pics of good loads while you are in the yard or wherever you see one. You can always use that for a reference. Also pay attention to other drivers. You will be able to tell whats good and whats not. Seeing both is helpful. As a flatbedder, take pride in how your load looks. We all check each other out.
  11. Calregon
    170
    106
    Dec 8, 2013
    Oregon
    Didnt read everything before I responded. Pretty much what Hurst said is it.
