Fl Classic XL Help With Wheel Cut, Turning Radius
Discussion in 'Ask An Owner Operator' started by Truckie6674, Jan 23, 2021.
  1. Truckie6674
    Truckie6674 Bobtail Member
    15
    33
    Jan 10, 2021
    Bought a Classic XL and just need a gun turret to be classified as a battleship along with its lack of turning.
    Need help to make it turn more,
    What have you guys done to yours?
    Help please
    alds and D.Tibbitt Thank this.
  3. Dino soar
    Dino soar Road Train Member
    4,589
    21,825
    Dec 8, 2017
    The classic with a set forward front axle, just like any truck with a set forward front axle and a long wheelbase, takes a football field to turn around.
    In contrast the famous FLD120 with a setback front axle will back you into places you could never imagine.
    So unless there is something really wrong with your truck that's just the way it is.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,203
    5,713
    Oct 22, 2016
    North Dakota, Eh?
    Turn in stoppers by kingpins. Other than that, nothing you can really do.
  5. AModelCat
    145,376
    Adjust axle stops and steering box if needed. Can only go so far before the tires start rubbing. Might get a couple more degrees of wheel cut.
  6. Hulld
    Hulld Road Train Member
    2,882
    6,561
    Oct 19, 2015
    Upstate NY
    Does it turn equally bad in either direction?
    Or is better in one direction?
  7. Truckie6674
    15
    33
    Jan 10, 2021
    Pretty bad in both, coming from a columbia, the classic seems to be going straight when the wheel is all the way to one side
    D.Tibbitt, Rideandrepair and Hulld Thank this.
  8. Hulld
    2,882
    6,561
    Oct 19, 2015
    Upstate NY
    Ok
    If it’s close to equal your steering linkage is phased probably.
    So like others have said you can only gain a slight amount by adjusting the stops but that’s it.
    On another note I have a Columbia and I am at 75 feet and can put the truck about anywhere I want to.
    With the set back axel it’s a whole different animal.
  9. tarmadilo
    tarmadilo Road Train Member
    1,372
    3,487
    Dec 12, 2018
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,504
    Jan 21, 2015
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,039
    Nov 18, 2014
    Land of local
    That and I've heard stories if you go too far they can lock up on you
