Flasher turn signal issue 2001 fld120
Discussion in 'Freightliner Forum' started by lciambotti1, Aug 27, 2017.
  1. lciambotti1
    lciambotti1 Light Load Member
    107
    19
    Mar 6, 2015
    Since yesterday when I either turn my flashers on or turn signals they just stay on and don't blink. I suspect the flasher but can't tell which one it is. Some of the labels have fallen off. And help?? Or should I be looking at something else?? Thanks
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Locate the flasher and feel for heat if nothing replace one or both one's for the turn signal one is for the 4 ways
  4. Loaderlou
    Loaderlou Medium Load Member
    342
    130
    Feb 24, 2014
    If you changed from incandescent to led, make sure you add an incandescent bulb or two in the system. I added a 2" marker in each head light pod. When one of those bulbs goes, it will slow down or stop the directional from working
  5. lciambotti1
    107
    19
    Mar 6, 2015
    Anyb
    Any idea which relay it is? Most of the paper tags have fallen off.
    swaan Thanks this.
  6. Kason2015
    Kason2015 Bobtail Member
  7. Kason2015
    Does anyone by chance have a diagram of the fuse and breaker box on a 2001 fld120? I need to check some and most of the tags are gone and the sticker on the cover is gone as well.
  8. RocketyMan
    RocketyMan Medium Load Member
    528
    311
    Jun 5, 2015
    You need to create a new post with your issue...and add your vin.
