Flashing check engine light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by twinlakesent, Nov 30, 2013.
  1. twinlakesent
    twinlakesent Bobtail Member
    4
    One of our trucks we just purchased has a check engine light that is flashing....any Ideas to toss around, its headed to get scanned now but thought I would ask some advice or reasons that may be the cause
    Its a 2007 KW T600, with a C15 in it. 207,000 mile on a rebuild from KW
    thanks
    Shannon
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
  4. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,868
    Sep 18, 2007
    Weatherford, TX
    Could be a million things. On some you can turn off cruise and hold down set lever and it will do self diagnostics. Count flashing lights and then see what code means. Used to get them 94 and 96.. Were actuator faults. But with no info there is no way to even make an intelligent guess.
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    A flashing check engine light is a typical indicator that the engine is about to shut down when they are programmed for idle shutdown. Does your light flash all the time, or just when it has been idling for a while?
  6. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    Flashing means the fault is active.
  7. Heavyd
    7,804
    6,253
    Feb 4, 2009
    What does a solid light mean then?
  8. Gear head
    532
    91
    Apr 1, 2012
    Belair,md
    Well I kind of worded it wrong. Flashing means the fault is active and happening now a solid light means the light was flashing and stopped. When the key is turned off the light will go out. If the problem is happening it will never stop flashing.
