Flat tire emergency kit, are they useful as a permanent solution?
Discussion in 'Ask An Owner Operator' started by AlexanderK, Dec 29, 2018.
  1. AlexanderK
    AlexanderK Light Load Member
    156
    95
    Mar 11, 2017
    I’ve got a nail somewhere last night on supersingle. I was wondering if I could use those flat tire emergency kit as permanent solution or should I look for tire repair place?
  3. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    You can use those tire kits... I've done it several times... do you have an air hose on the truck? I used it on my other truck... it held for over 6 months
    AlexanderK Thanks this.
  4. Highway Sailor
    Highway Sailor Road Train Member
    1,328
    1,659
    Nov 23, 2011
    Erie,Pa.
    Look for a tire place. Having a deflated super single will get you in trouble fast and waiting for road repair.
  5. kemosabi49
    10,735
    46,219
    Jan 13, 2013
    SW Arkansas
    One time I ran over something in the dirt at a construction site. I could hear the air coming out and had a nail sized hole in a trailer tire, Out in the middle of nowhere. Another driver covered a screw with silicone then screwed it into the hole. Used my air hose re-inflate the tire and made it to the next shop without losing any air.
  6. AlexanderK
    156
    95
    Mar 11, 2017
    I’ve got tire inflation system on the trailer. I have air hose as well for the tires of the truck.
    I’m just wondering if those DIY kit could be used as permanent solution, or I still have to go to tire place even I fix it. If I still have to go to tire place, I wouldnt bother with the kit.
  7. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    Well for a permanent fix I would go to the tire place... if they can't fix it then at least you know what you gotta do..
  8. ZVar
    ZVar Road Train Member
    10,911
    23,829
    Sep 10, 2010
    Flint, MI
    The one time I seen price, it was $35 to pull the tire off the rim, place a patch on the inside and remount. For the price, the piece of mind is worth it to me.
    npok, Dino soar, mitrucker and 2 others Thank this.
  9. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    I use tire plugs until I can get tire shop to patch properly. Use tire plugs only on my personal vehicles as permanent fix
  10. AlexanderK
    156
    95
    Mar 11, 2017
    Thanks for all your responses. With tire inflation system, I will get to the tire shop then, and won’t mess with the kit, since it can’t be used as permanent solution.
  11. xsetra
    xsetra Road Train Member
    5,130
    7,024
    Aug 21, 2011
    I use the emergency plug to get to tire shop. Then have the mushroom plug/patch put in.
    I recommend not having air leaking from tires while driving.
    Good luck.
    Tb0n3 Thanks this.
