Flatbed for a new grad?
Discussion in 'Questions From New Drivers' started by CCJR76, Feb 11, 2013.
  1. CCJR76
    CCJR76 Light Load Member
    151
    71
    Oct 15, 2012
    Jacksonville, FL
    Is going into flatbed right out of school a good or bad idea(for the companies that will hire new)? I know the physical labor involved, but are there many cons to it given Im a "newbie"? Thanks for the replys..
    Chinatown Thanks this.
  3. TripleSix
    129,749
    You will be fine. The way I see it, you can either drive or you can't. Doesn't matter what kind of wagon you pull. If you want to skateboard, go ahead and start shredding right from jump street.
    HauntedSchizo19 and CCJR76 Thank this.
  4. Chicken Legs
    Chicken Legs Bobtail Member
    33
    12
    Jan 2, 2012
    No problem! Find a company or someone to show you the ropes on proper load handling & chain down and go to town!
    CCJR76 Thanks this.
  5. Poacher
    Poacher Medium Load Member
    338
    280
    Feb 8, 2013
    Let me know how it goes. Thats my plan when I get my Class A. I think as long as you have the want to you can do anything. Just learn as much as you can and be carefull. Good luck!!
    CCJR76 Thanks this.
  6. wideglide13
    wideglide13 Light Load Member
    228
    53
    Jan 30, 2013
    Anywhere USA or Canada
    Yes it does matter What trailer you pull and what is on it !! That attitude is why you see coils break loose and roll right through the cab and kill the driver
    SheepDog Thanks this.
  7. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    I pulled a Trailmobile Eagle with a 10 ft spread between the axles. You can't get them overweight if you are under 80,000. Can't go to Canada either which to me was great. See my pic? Thats 2 coils of aluminum on end. Our safety man said "If you wreck and have chains left in the rack, you'll pay. If all your chains are on the load, I'll pay." Make sure you never load a stack of pipe in a triangle shape, leave 1 off the top and wrap straps around it to hold it together. Carry a good camera, just when you think you've seen it all, you haven't! There's no good in an evil hearted woman.
    We are all time travelers moving at the speed of exactly 60 minutes per hour
    CCJR76 Thanks this.
  8. wideglide13
    228
    53
    Jan 30, 2013
    You can go to canada with 10' spread but limited to Ontario, Montreal ,New Brunswick
  9. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    You get double points your first year for violations and flatbed has alot out in the open to inspect. Just something to be aware of, but I wouldn't worry much about it.
  10. wideglide13
    228
    53
    Jan 30, 2013
    Double points first year ? Maybe i should ask for a explanation before i say you are a idiot dumb ### ?
  11. TripleSix
    129,749
    and being able to secure a load doesn't indicate that you can drive, does it amigo? This person asked whether not not he would be okay to start his driving career in a skateboard. Do you have a valid reason why he should not?
