Flatbed guys what are you running? Truck/trailer
Discussion in 'Expediter and Hot Shot Trucking Forum' started by crocky, Mar 7, 2020.
  1. crocky
    crocky Road Train Member
    1,732
    1,577
    Jun 28, 2017
    I'm running a 2005 F350 SRW with a Trax 14k 36ft lowboy. The trailer is similar the ones Load Trail makes but better quality. It doubles as a 2 car hauler or flat deck. A jack of 2 trades but a expert at neither, I can load roughly 10k lbs but I usually don't go over 9k just to be safe.
    I'm thinking of upgrading my set up to a F550 or D5500 and then a straight up 40ft flat bed with the mega ramps. There is so many loads I'm seeing on the boards that I can't do with my set up, so I'm looking to upgrade. I'm curious how many guys are hauling heavy as hot shot and how much weight can you carry?
  3. 24kHotshot
    24kHotshot Heavy Load Member
    801
    874
    Feb 19, 2019
    New York
    I'm not flatbed but I drive a Ram 3500 cab and chassis and tow a 26k. My truck and trailer empty weigh a bit over 18k. Truck a bit over 9k and trailer is about 9k
    I'm rated for 40k lbs and the heaviest I've been is 38k towing 3 diesel pickup trucks. Truck does well at 38k but I wouldn't want to be that heavy all the time. Comfortable at 33k.
    Just put a down payment on a custom low profile step deck auto hauler because I'm losing out on good loads my wedge cant take because of height and wind resistance with a car on top is hurting my mpg. Might fill in the middle gap and try to grab some freight when it's worth it.
    If I had to start over I'd look for a single axle semi.
    singlescrewshaker Thanks this.
  4. singlescrewshaker
    4,794
    41,785
    Dec 31, 2017
    Little Havana, FL
    Don't waste your time running a "heavy hotshot".
    I ran mine at 36k lb gross with 17k lb on deck. It was fun & all but for all the same hassle you can run one of these joints. Full truck loads, better bunk, virtually same fuel mileage. You can get this whole rig cheaper than a new 4500-5500 before the upfit. Then cost of new gooseneck wagon..
    That's ~26000lb on deck.. I can deck 28,300lb @54999 gross. No 2290, no kyu. No different than when I was a 36k lb 1 ton..
    Also that hotshot will be toast when you're done with it. Even if my truck is scrap, this aluminum wagon will be worth $20-$30k..
    tnpete, Xray4, Coffey and 2 others Thank this.
  5. crocky
    1,732
    1,577
    Jun 28, 2017
    I've driven semis before. I'm not really looking to go back to them.
  6. singlescrewshaker
    4,794
    41,785
    Dec 31, 2017
    Little Havana, FL
    Well to answer your original question ~17k lbs on deck is what I did max at 36k gross. 2012 1 ton ram.. The trailer was good for about 20k. Put 20k on it plenty of times behind this shaker while I was transitioning.
    I know the new pickups are "rated" for 40k or 42k gross. They will do it, but won't last very long grossing that kind of weight on the regular..
    Mine was only rated for 21k gcvwr. 6.7 Cummins 3.73 g56. It was a good truck.. this was about 16k of aluminum tubing, so 35k gross..
    clausland, crocky and 24kHotshot Thank this.
  7. 24kHotshot
    801
    874
    Feb 19, 2019
    New York
    I wish I can find a big block M2 112 crew cab that isn't a sportchassis or costs like a sportchassis. Smaller than a semi, plenty of cab room/sleeper, more power than a 1 ton and air brakes to stop that heavy load. Throw on an APU and you're golden. I personally like the way they look.
    I'd say that would be a perfect Hotshot rig that can haul heavy safely and comfortably.
  8. crocky
    1,732
    1,577
    Jun 28, 2017
    I sort of eyeball the F650's... I dunno if I'd go to that but man they can come set up with Ford body/chassis, Cummins engine and Alison trans. It's a bit smaller than a M2 I think, but you can get them as crew cabs.. Can even get air brakes on them for the tractor but don't think they do air brakes for the trailer.
    Whatever I get next I'll add a sleeper to it, so I'm not so worried about that aspect, but APU's are heavy. Go with a Onion RV genset with a RV AC unit. Much lighter combo.
    The biggest problem I think about is.. am I better to do what I did with my current truck.. Buy a decent used one fix it up and have $10k or so in it and be a throw away adter a year or 2 or buy a $65k truck... and pay $12k/year in payments but be stuck in it...
  9. crocky
    1,732
    1,577
    Jun 28, 2017
    Yea something like that would be good for me, I'm not looking to go over 20k lbs on the deck but I was leaning toward a 550 not the 1 ton.
  10. Lite bug
    Lite bug Road Train Member
    1,405
    30,416
    May 3, 2014
    Columbus Ohio
    Here singlescrewshaker gives the natural progression most everyone goes thru if they stay in this business. I have a friend who went thru the same progression all along his brother in law suggesting you should get a semi. Now the one saying to upgrade has drove big truck over 40 years. Now he admits he wasted a lot of money going his own way. There is a guy on here that runs a hotshot for about 25 years and he will not load over 15k on his trailers They mainly run freight and use cars to fill in so the are not competing against the semi car carrier. I believe Singlescrewshaker runs freight and uses cars as a filler. This is the information I have learned from these guys, me personally I run the lightest freight possible. I don’t put over 5 k on my trailer. I run stuff for the electric grid, I do not complete for this stuff, I wait until they call me.
  11. singlescrewshaker
    4,794
    41,785
    Dec 31, 2017
    Little Havana, FL
    This is the closest thing to a car I have ran with the step. Matter of fact, a Cadillac Escalade is really the only car like thing I think I put on my hotshot. The dove tail monster ramp set up was not really all that good for cars. A 2wd f150 I would have to block up with timbers so the front air dam wouldn't be damaged..
    Usually the only vehicles I move are transfers for equipment rental yards. Nothing against cars, I personally didn't see the right $ for moving 1 or 2 when I needed too..
    I have nothing against a hotshot that knows their sheet. I can't stand when I see one with all the freight loaded at or behind the trailer axles. Load your drive!! Driver!! Jackknife waiting to happen.. :eek:
    But yep, being based in FL I struggled with the hotshot. I survived it, & moved on to something that is better suited for the spot market. I say this all the time, but was so sick of hearing sorry, we know it will fit, but No Hotshots.. :confused:
    If I had direct freight that kept me in the money like @Lite bug I would've stayed with it.. Any way you choose, I hope you succeed.. From a business standpoint, this puts more money in my pocket, which is why I do this.. :cool: In this bad market we did $6440 last week, & $5350 this week on less than 2000 miles..
    clausland and Lite bug Thank this.
