Flatbed length
Discussion in 'Ask An Owner Operator' started by mxell, Nov 30, 2007.
  1. mxell
    mxell Bobtail Member
    13
    essex, England
    i was looking at flatbed trailers earlier, ive seen 45', 48' and 53' trailers, if i was to buy a 45' flatbed would there be loads i couldnt take, that would require a 48' or 53' trailer? if so are there a lot of loads that require a 48' or 53' or would i be alright with a 45'
  3. broncrider
    broncrider Road Train Member
    with a 45 you will get higher loads than a 48 becuase of space requirements
    what that means is lower fuel economy
    the same load on a 45 compared to a 48 doesnt look the same at all...a 45 is alot higher here in lumber country....steel not so much of a differnce
    a 53 is a waste of money IMO unless you hual alot of styrofoam...theres just too much trailer for lumber and steel loads witch means alot of empty space on a grossed out load
  4. Etosha
    Etosha World Citizen
    745
    50
    Aug 19, 2007
    Edmonton, AB
    Seems to me that you need to know what you are going to be hauling before deciding on the trailer...
  5. nerok9
    nerok9 Light Load Member
    98
    6
    Jun 21, 2007
    What type of trailer has more freight that it can carry
    1. Flatbed
    2. Stepdeck
    Please give input on what you O/O have seen out there for freight for these.
    NeroK9
  6. pochop7
    pochop7 Light Load Member
    51
    Nov 20, 2007
    Zephyrhills,Florida
    A 48foot is the way to go, a 53 is a waste, and a 45 sometimes isnt enough.
    As for a regular flatbed and a drop deck it depends on what your carrying. I prefer the drop deck 1-closer to ground so its easier to get on 2- closer to ground so your center of gravity isnt as high 3- you can haul taller loads that would be over height on a regular flatbed 4- they make frames that go on the drop deck to extend the platform and make it as long as you need it( same height platform that is above kingpin) Downfall- if you have to back up to a dock it cant be regular dockheight
    All depends on what you will be hauling
  7. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    If i was buying an all around trailer for any occasion and general commodity in the flat bed arena it would be a 50' step with spread axles and a 10 ft top deck. Just my overall best fit for any conditions.
  8. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    A 45 here in the states is going to badly restrict what loads you can get.
    Go with a 48 x 102. Only 96 wide will restrict you also, but not nearly as badly as a 45 long.
