flatbed rate: how much it is now
Discussion in 'Freight Broker Forum' started by rilla, Jul 7, 2013.
  1. rilla
    rilla Bobtail Member
    21
    Jan 28, 2010
    arcadia ca
    sounds even worse than last year, some even worse than dry van:biggrin_2558:
  3. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    Yep, rates are terrible so pull reefer or vans....:biggrin_255:
  4. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    966
    Apr 21, 2013
    Salem, or
    would depend on which company, area etc. Talked with a Melton driver recently and he said he made very good money and has been doing flat bed for over 20 years starting with swift. A couple others I heard make decent money too, it just takes more work having to tarp and all that stuff but you also get tarp pay to do it.
  5. keepontrucking81
    keepontrucking81 Light Load Member
    210
    41
    Jun 27, 2013
    Chicago, IL
    Flatbed rate owner operator not less then 2 dollars, a mile
    cetanediesel Thanks this.
  6. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Huh??? It all depends on the lane. I've seen flatbed rates at less than .50/mile. Its all that way every part of the industry has cheap freight reefer van flatbed etc. There's always cheap stuff somewhere. It all depends on the lane and freight. I still get a kick out of a reefer rate changing a whopping .30cpm for a town that was all of 12 miles away. Its the same way everywhere though all depends on the lane and trucks. Supply vs. Demand. Have to remember that. Ever checked rates out of south Dakota, Wyoming, or Montana for a flwt if you can find a load? Pretty pathetic when a 1000lb partial pays better than 48000lbs of lumber. What's even better is when the dispatcher tells them to walk it there piece by piece :biggrin_2559:
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Flatbed rate is exactly $3.65/mi today :biggrin_255: and as a broker you need to bid higher than that. Add in what percentage you want for yourself. A broker needs to bid higher than a direct carrier as it costs more to feed two mouths than one.
  8. killer120
    killer120 Light Load Member
    70
    43
    Jul 1, 2013
    the rate is amazing if you find your own freight
    bullhaulerswife Thanks this.
  9. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    rates are crap if you're getting loaded out of truckstop.net or getloaded.com
    most carriers will get your 20-25% so you get 75-80% right after their cut translated to $PM means gross varies like crazy.. from 1.10 up to 3.50 a mile ,
    it haven't gone up in a long ssa time, still everything else goes up, crazy..
  10. killer120
    70
    43
    Jul 1, 2013
    is that why my best friend works for landstar inway and lease a used truck and a new trailer and still make 6-8k a month after all expenses and only drive 9-10k miles per month
  11. killer120
    70
    43
    Jul 1, 2013
    and mind you they still take 25%, the thing is he's not an idiot like some of you guys who take a load only worth $1 per miles, the minimum he will take is $2 per mile
