Flatbed setup???
Discussion in 'Ask An Owner Operator' started by Texasrig, Jun 8, 2022.
  1. Texasrig
    Texasrig Light Load Member
    144
    125
    Mar 3, 2022
    I’m currently running two dry vans and I’m thinking of getting a couple of flatbeds ( $2 more a mile on avg). So my question is this what all do I need? I know chains,straps, bungee cords, tarps, tonnage wood. Anything else? By the way I’m running primarily in Texas, I’m getting about $5 a mile in the vans but can get $6-8 pretty easy down here
  3. Kenny Vader
    Kenny Vader Bobtail Member
    13
    32
    Apr 26, 2022
    It looks like you have it covered.I run flatbed from Texas to the Pacific NW. Kinda depends on what you will be doing. Most guys that do Texas carry 6'drop lumber tarps,4 sets of coil racks, and 10 -5/16" 20' Grade 70 chains. And 18 straps.I have known guys that have straps only. That just puts limits on what you can do.
  4. Texasrig
    144
    125
    Mar 3, 2022
    Thank you. One more question have you noticed rates dropping? Because I haven’t really seen it yet, I consistently get $5 a mile in the van even from brokers like TQL. The only place I feel the pressure is at the pump to be honest.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    865
    1,685
    Dec 15, 2021
    Winch bar and some edge protection for the straps.I always had 8 or 10 of the smaller 90 degree ones stashed in the truck.We always kept a box full of the small wedges for pipe,with some nails and a hammer.Nail the wedge on a 4 x 4 when hauling pipe or drill bits,along with a couple pieces of C channel 3 ft long or so,put in the pockets along the edge of the trailer when loading big pipe.
  6. staceydude
    staceydude Road Train Member
    1,146
    4,993
    Apr 3, 2020
    You guys realize that flatbed rates aren’t going to hold up much longer either. Plus they will drop as the weather starts to cool off again and that is closer than what some think. Lots of dead flatbed areas as well.
    All I’m saying is be careful you don’t dump money into something that will go the way of the dodo bird before it benefits you.
  7. Kenny Vader
    13
    32
    Apr 26, 2022
    Excellent point. Personally, I would stick to the vans if you are getting$5 pm. If a guy is just starting open equipment in our current situation it may be a tough learning curve.
  8. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Smoke tarp
    ½ 8 foot drop 24’ long (will cover ½ trailer), 3 x steel tarps 24 x 16 or your preferred tarp setup.
    Cloth padding for under tarp or Carpet pieces – cover corners/edges
    31” bungees
    Tarp patch kit
    Straps 14 to 18 – 30’ straps
    2 pocket winches
    2 - 4 inch ratchet straps
    4 to 6 - 2 inch straps
    Sliding winches on trailer
    28 plastic edge protectors
    2 winch bars (just in case you lose one)
    Hammer/nails for dunnage (or screws/drill)
    6 – 2 inch straps
    2 to 8 4x4 (Dunnage)
    12 chains & 12 ratchet winders
    Ladder
    Rod for belly strap and rod for high edge protector placement
    Hard hat, gloves, vest
    Rubber mats for b/n steel/wood
    Antifreeze/oil
    Headset
    coveralls
    I'm sure I am forgetting something.
  9. Diesel Dave
    8,740
    25,160
    Jan 20, 2010
    Hesperia, Ca.
    If your not familiar with what you need, your not ready. Skateboarding can be very challenging, it’s not a walk in the park. You have to be aware of your securement regulations. I would stick with door slamming if your getting that much of a rate.
