Flatbed/Step deck
Discussion in 'Flatbed Trucking Forum' started by Dino soar, Apr 9, 2025.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I've done research but I'm curious what anyone thinks between a flatbed and step deck.
    Is it true that pretty much anything you can haul in a flatbed you can use a step deck if you have load levelers?
    The step deck is also a little heavier I believe than the flatbed.
    Some of those flatbed loads are pretty heavy because the trailers are so light.
    Is 48 ft sufficient?
    When the Brokers list the load as flatbed, do you normally call on those loads and ask if you can use a step deck?
    CAXPT, D.Tibbitt and OldeSkool Thank this.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,015
    2,086
    Dec 15, 2021
    I have a 48' flat.If you have a stepdeck and they request load levelers they want factory or manufactured ones usaully.
    The stepdecks can haul freight that's higher than you can put on a flatbed so those generally pay a little more,from what I've seen lately.
  4. Concorde
    Concorde Road Train Member
    5,483
    19,494
    Jun 29, 2016
    West Melbourne Florida
    What are you pulling for a trailer now?
    I may turn my van into a flatbed :)
  5. North Pole Nightmare
    1,015
    2,086
    Dec 15, 2021
    Some of the stepdecks have the locks that you can set a container on your trailer and haul one of those.
    CAXPT, Dino soar and D.Tibbitt Thank this.
  6. Diesel Dave
    9,689
    33,006
    Jan 20, 2010
    Hesperia, Ca.
    My next trailer is going to be a step with a couple of load levelers. 48’x102”. “IF” I decide to pull the trigger.
    Speedy356, CAXPT, Dino soar and 2 others Thank this.
  7. D.Tibbitt
    157,241
    If running a stepdeck you would want to get one with ramps as well... otherwise u will be missing out on alot of freight on the spot market.... me personally I think a flatbed is easier to keep loaded on a load board but it's just been my experience... step deck is good for putting together partials and ltl loads.. not all places will load a step with levelers. Think anything longer than 40ft like steel beams or rebar or stuff that's loaded with overhead crane.. will be flatbed only.. also u will want to be as close to 32k empty or less or u will not be able to get loaded alot of bulk material places that want to load 48k
    Ok big boy, CAXPT, cke and 4 others Thank this.
  8. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    My first trailer was a flatbed. I owned it 30 days. Traded for a stepdeck. The lower deck is closer to the ground. Easier to get up on the trailer all around. Well, it used to be easier (age). To secure loads with chains and straps.
    I don't tarp loads anymore but, that was easier as well to get bungees on tarp.
    Loads that ask for flatbed I don't call on. I call loads that list a SD, FBSD, SDRG. I look at the SDRG loads, usually pass on, because the load belongs on a RGN not a step deck.
    Flatbeds are usually lighter than Stepdeck. If you buy an all aluminum fixed axle trailer. Weight can come in close to a combo flatbed.
    I don't have risers or ramps. Sometimes it takes extra time to find loads versus having the extra equipment. Empty weight has to be considered and what to compromise to have a decent empty weight.
    CAXPT, cke, Dino soar and 1 other person Thank this.
  9. Big Road Skateboard
    7,118
    40,410
    May 2, 2021
    If your gonna limit yourself to a certain area, or certain restrictions, you'll be better off with a 53 flat.
    I bought a 48 cause everybody said that's all i needed. Wish I had gone 53'
    Anything to make you more versatile will keep you loaded.
    53'
    Pipe stakes
    8' tarps
    20+ winches
    A light truck is also nice. Those loads over 48k often pay a premium
  10. Walk Among Us
    Walk Among Us Heavy Load Member
    962
    5,268
    Mar 3, 2025
    Fort Worth, TX
    From a company driver perspective, I prefer flatbed loads but you could make move money doing taller loads I guess. I don't like tarping loads that are uneven.
    CAXPT, D.Tibbitt and Dino soar Thank this.
  11. Dino soar
    4,815
    27,071
    Dec 8, 2017
    My Freightliner is under 19,000 lb.
    So that leaves me 13,000 lbs.
    Probably a 10,000 lb trailer or so would be best.
    That would probably be about what a combination flatbed would be.
    I stay as close to the Philadelphia / Allentown / South Jersey / Delaware area as I can.
    I have no interest in going any farther.
    Haven't seen many 53s for sale, though.
