Apparently I cant find the right keywords to search for my question...
1. What is the deal with some flat/step trailers having steel or aluminum plates on the deck? I've seen some over the wheels, and some at the front of the lower deck.
Are they load bearing? Just for clearance with smaller tires?
2. What are the pros and cons of having 19.5 or 17.5 tires vs 22.5s?
Obviously lower deck height, but what else?
Flatbed Trailer questions, aluminum plates on the deck? Tire sizes?
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, Jan 19, 2019.
Aluminum on the deck is to reduce weight.
Plates over the wheels is to allow for tire clearance. They are load bearing, but usually it's not as strong in that area as the rest of the deck.
The advantage of smaller tires is just like you think, to get a lower deck height, and nothing more. The disadvantage to smaller tires is, they usually don't have as high of weigh rating, they wear out faster, and have more blowouts. So there is a pretty big sacrifice for running something as small as a 17.5, but that sacrifice is justified if you need the low deck to stay within legal height on some loads.stwik, cke, Tug Toy and 1 other person Thank this. -
stwik and johndeere4020 Thank this.
RollinThunderVet Thanks this.
That's what I was thinking. Either load/customer specific or damaged deck and just replaced with plates...
Should that placement effect most loads @johndeere4020 ?
I would imagine if thick enough, the load rating would be negated...
