Fld 120 possible motor mounts / clutch problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trugo, May 10, 2019.
  1. Rideandrepair
    17,572
    56,926
    Aug 8, 2015
    Take the time to cut a large block of wood to wrap around trans and catch both sides, that way it can’t slip, Small plate is between engine block and bracket, must be sacrificial dissimilar metals plate, maybe to keep block from corroding ?
    Trugo Thanks this.
  3. wore out
    wore out Numbered Classic
    17,386
    216,023
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Thanks you hopefully just solved a mystery for me. I had my engine out of my 91 not long ago. It's got a little vibration that has been hard on my mind since I got it back together. Atro is what i went back with.
    What do you have the best luck with?
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Check that leak very well. There is nothing quite the feeling of doing a job like that to find out that was not the problem. Sometimes I stick a rag in the blowby tube for a bit. The little extra pressure helps find the source of some leaks.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    OEM rubber. Only thing I use ATRO on is Mack engine/trans mounts. To hard in most applications.
  6. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,202
    Jul 12, 2017
    Their tracking rods are killer and outlast the OE 2 to 1 in severe applications.
    Too hard is not always a good thing, as you pointed out.
  7. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    I just welded a tracking rod bracket back on a 46K Meritor axle this week on a Pete with a Haulmaxx suspension that was all Atro bushings. It beats you to death empty! Put the new style Hendrickson steel tracking rod back in. I know on lift axle bushings, rubber outperforms poly 2 to 1. I like some of Atro, just a place for both I guess.
  8. Rideandrepair
    17,572
    56,926
    Aug 8, 2015
    I used the anti-walk bushings on my Classic. They’re a harder ride, for sure. Holding up well though. Just noticed my super duper poly motor mounts are shot already, after 5 yrs. I’m going back to original rubber. I like the anti-walk idea, as Freightliner has a problem with that. But I stand corrected on poly being better, for all apps.
    jamespmack Thanks this.
  9. jamespmack
    216,656
    This holds true with a poly carrier bearing bushing. Lasts for ever however.
    Rideandrepair and wore out Thank this.
