My single dual exhaust has rusted through in a few spots and I want to do dual stacks on the side. I've been looking around and some sites will say classic, others will say FLD, and others will say FLD & Classic. This leads me to believe that the routing is the same on both models and I can order either one. Does anyone know for sure?
FLD120 vs Classic exhaust routing
Discussion in 'Freightliner Forum' started by dlstruck, Jun 12, 2017.
I would swing by a dealer with your vin and see if they can give you a parts breakout for all the pieces and they you can go shopping from there.
Classic and Fld 2 different models some what. Main difference is the hood. Make sure you install the heat shields, if not you have a good chance of melting air lines under the cab...
DDlighttruck Thanks this. -
I'd search truckpaper for the same truck you have but with stacks and use that VIN.
Roberts450 Thanks this. -
I have a 99 Fld120 single stack, by the passenger door
