F'liner Columbia speaker size????
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by 2sN5s, Jun 18, 2010.
  1. 2sN5s
    2sN5s Light Load Member
    84
    29
    Dec 12, 2009
    The Bronx NY
    Does anyone know the factory speaker size for a Columbia? called F'liner and of course they won't tell you unless you buy from them.
  3. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    In mine they are 5.25", I went to ChinaMart and bought some Sony speakers
    that size and they fit right it, sound really nice also..
  4. Chris M.
    Chris M. Light Load Member
    123
    87
    May 27, 2010
    Tater State
    Just measue across the speaker opening in the door. Then go buy and install. IF YOU are unsure on the polarity just use a volt meter. Wouldnt wana ruin new speakers would ya? Good speakers go along way but your deck is your sound processor so a good deck can make ok speaker sound good but not great. If its your truck and not a company i would spring for a new deck and speakers and run the wires yourself. If you have any more audio questions just ask, its a hobby of mine.
  5. punkinhed
    punkinhed Medium Load Member
    345
    122
    Sep 19, 2008
    hello, cleveland!
    you won't ruin speakers by wiring them backwards. if they're both backwards everything will be cool. but if only one of them is, they'll be going push-pull instead of pushing the air at you, and you'll get a weird phasing effect (that most people don't even notice.)
    danozar Thanks this.
  6. RustyChops41
    RustyChops41 Light Load Member
    206
    186
    Apr 25, 2016
    Clovis, CA
    On this very topic, has anyone replaced all four OEM speakers in a current (2016) Cascadia? I've had the grills off, and while they don't look crummy they sure seem weak, even at low volumes. (Weak as in frequency response, on the upper highs and lower lows). It would be a snap to swap them out.
