How much different is it floating gears in a big truck from floating gears on something like my old 6 speed f350? I understand clutching is different and synchronized vs non-synchronized manuals, but what about floating?
Floating gears
Discussion in 'Questions From New Drivers' started by Buffalo444, May 4, 2012.
It is the exact same! Its all timing of aligning the gears so that they slip into place together. If you can float in your f350 you will be able to float in a big truck. May even be easier for you. Now in a big truck though you are going to need to downshift a little more. As long as you have been doing that too you will be fine. (down shifting requires revving up the rpm's to match your speed)
Onetruckpony Thanks this. -
If you put these on
you shouldnt have any trouble.
The dead horse is starting to complain about being kicked.
DrtyDiesel Thanks this. -
Personally I don't get why nobody's ever made HD synchro rings yet.
