Fluid Damper- Vibratech vs ???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 3406eStar, Jan 28, 2013.
  1. 3406eStar
    3406eStar Bobtail Member
    15
    Jan 18, 2013
    Just finished an in chassis on my 3406e CAT. Looking for a Vibratech Damper, or one that's just as good. I've found fluid dampers from PDI and Pittsburgh power, but neither lists the manufacturer of their part. Does anyone know if either of these is actually a repackaged Vibratech, or know anything about their quality? Or maybe know who lists the actual vibratech piece?
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If the dampener is not bent and if you take it off and bounce it on the tire and it does not rattle it is still good. Cummins is the only one that when doing a full warrentable overhaul supplied a dampener. The dampener is not of any use if the RPMs are below 1800 on most engines, that includes Cat if the dampener, with the rubber separator fell off, that was what we told the driver, keep your RPM below 1800 and you will be OK.
  4. 3406eStar
    15
    Jan 18, 2013
    I was told that the 1LW 3406e CATs were prone to crank failure, and that it was due to the fluid damper losing viscosity, and therefore no longer doing it's job. My motor is a 1LW.
  5. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    PP sells a Vibratech damper not even repackaged...
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,728
    Jan 30, 2010
    keep stroking.
    i would change it, for about $500 it's cheaper than a crank!!!
  7. bdinkyboy1
    bdinkyboy1 Bobtail Member
    35
    12
    Apr 22, 2012
    Thomson, GA
    I purchased one from PP last year for my Detroit, and it was a Vibratech.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    You are correct, I was rold the same thing from Bruce at PP.
    I called Vibratech to order a balancer for my CAT, they said just call PP. I had it in a few days.
    And when the crank breaks, you'll be lucky to not destroy the block too.
  9. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Mr Haney hooked me up with my damper and balancer. His price was as good as anybodies.
  10. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Has anyone kept their factory damper and just added the balancing ring.
  11. 3406eStar
    15
    Jan 18, 2013
    My research shows that they do two different jobs. Balancer seems to do a great job smoothing out vibration, therefore reducing wear, breakage, etc. but the dampers job is to counteract torque flex / shear factor. I don't think I'd trust the addition of a balancer to pick up the slack of a damper that may be on it's way out.
