FMI 5 SPN 3361 / 2012 Cascadia...Need help diagnosing the problem / CEL MIL lights
Discussion in 'Freightliner Forum' started by Emil Baran, Apr 4, 2017.
  1. RocketyMan
    RocketyMan Medium Load Member
    549
    337
    Jun 5, 2015
    Doubtful...did you get a DEF quality fault code? I don't see a correlation to open circuit fault code and "poor" quality DEF...
    mhyn and Emil Baran Thank this.
  3. Emil Baran
    Emil Baran Light Load Member
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Just got additional code
    fail 2 spn 3364
    DEF QUALITY
  4. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    And another one
    fmi 1 spn 3361
  5. RocketyMan
    549
    337
    Jun 5, 2015
    3364/2--Aftertreatment 1 Diesel Exhaust Fluid Tank 1 Quality Data Erratic, Intermittent Or Incorrect
    3361/1--Aftertreatment 1 Diesel Exhaust Fluid Dosing Unit Data Valid But Below Normal Operational Range - Most Severe Level
    Basically you have a derate as per the spn 3361. You know...I wonder if you have a UQS on your truck. This would have been one of the very few in production that had a sensor in the DEF header. The truck should've got a recall to retrofit an analog header. Can you take a picture of the connector on your DEF header? I'll be able to easily tell what kind it is.
    Emil Baran Thanks this.
  6. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Yea just got derated to 55mph, ill stop in a bit and take a pic
  7. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    I-m doing a parked regn because i have CEL stop and MIL lights on.
    I just picked up load and need to get back home 350miles (i90 flat) to get that truck to a DEF guy.
    I need help from you guys
  8. RocketyMan
    549
    337
    Jun 5, 2015
    That's an analog DEF header....
    So..in this case, a couple of things. You could have a lazy NOx outlet sensor. You could have bad temp sensors. At this point, you need Diagnostic Link and determine if your NOx conversion stays above 70% and your temps...and various other things that you need to monitor.
    Something in your ATS is throwing off the calculation for perceived DEF quality. Maybe you have diesel in your DEF tank...or coolant. Not TOO big of a problem with this if you catch it soon enough and don't put off getting it fixed.
  9. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Well , it did the regen fo 45min ... but it still looks like 5mph derate with lights on. I need a trick to get that truck back home. Mechanic is waiting.
  10. RocketyMan
    549
    337
    Jun 5, 2015
    You'll just have to deal with the derate. You might be able to cycle the battery quick disconnect switch if you are equipped with one. But most likely you'll need DLink to clear the codes. And then verify what part is giving a faulty reading for poor quality.
  11. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    I disconnected the speed sensor. Got all 3 lights on but driving at 60mph .. 300miles to go. Prayers ?
