Fog question
Discussion in 'Questions From New Drivers' started by TruckerGonnaBe, Jan 8, 2015.
  1. TruckerGonnaBe
    TruckerGonnaBe Light Load Member
    140
    38
    May 27, 2014
    Western WA
    I know being a newbie is going to make me nervous to drive in fog but am I going over the top because I am a newbie?
    Last night the fog was so bad over 97 that at times I could only see a couple of car lengths in front of me and at times it was so bad that I couldn't see the road in front of me. I was ranging from as low as 10- 15 mph to upwards of 35-40 mph the farther I could see the faster I went.
    One time I could only see a couple of car lengths in front of me and a CR England truck passed me. I was freaked out because I was sure he was going to hit somebody in the fog it was so hard to see. But later more trucks passed me thankfully most of them had decent visibility when the passed.
    Am I just panicking because I'm the newbie? I talked to STT later after I got pulled over for a headlight that the company won't fix until I get to California and he said that I would learn and get better and drive faster in the fog.
    Is there a trick to driving in fog that makes it safer to drive faster? Maybe it is because I'm a newbie but driving fast in fog just scares me & I don't think I'm ever going to change driving slow in the fog like that. The question I posed to him was what if there had been a car there that couldn't be seen? I would hate to be the one to end their lives. He just laughed said I would learn.
    gpsman Thanks this.
  3. TripleSix
    132,760
    The trick to driving in the fog is to make sure you can come to a full stop within the distance you can see.
    Everyone doesn't have the same sight. And some people drive blind.
  4. bzinger
    bzinger Road Train Member
    16,635
    66,094
    Dec 10, 2014
    omaha , ne
    company wont fix headlite to you get to cali ?
  5. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    What's wrong with the headlight that you can't fix, generally it's just a Bulb.
  6. Allow Me.
    10,747
    12,485
    May 28, 2009
    Rancho Mirage, Ca.
    I've driven in fog many times. One thing sticks in my mind…….the number of people driving without their windshield wipers on. I mean, its foggy out, their windshield is glazed over with moisture, and they're just puttin'along. You see the same thing in icy weather. People drive too fast. They're the ones you see in the ditch up ahead.
  7. misc
    misc Light Load Member
    183
    133
    Mar 18, 2010
    Headlights from oncoming traffic can help you judge visibility distances. You can also use other vehicles as an early warning system. Keep them just barely in your sight, and slow down if they brake.
    Above all, stay in your comfort zone. Too many drivers charge full speed ahead, assuming the law of averages will keep them safe.
    Also, fix that headlight. They'll reimburse you.
  8. 201
    201 Road Train Member
    12,666
    26,039
    Apr 16, 2014
    high plains colorado
    I thought the same thing. What is this world coming to? 1st, I don't mean any disrespect, but changing a headlight bulb has to be 1 of easiest things to do on a truck. Generally, you open the hood, behind the headlight, you'll see a plug with wires going to the bulb, take the plug off, there should be a ring you unscrew, and the bulb will come out. When you put the new bulb in, don't touch the bulb, use a clean rag or new vinyl glove, as the oil from your fingers will cause the bulb to get hot and burn out again. There should be a small notch in the base of the bulb, so it fits in the holder right, replace the ring, and plug the wire back on.
    As far as driving in the fog, I used to hate the fog, it's like driving with your eyes closed. If you have a headlight out, that increases your chances of not seeing. Let the lunkheads speed by you, go as fast as you feel comfortable, and if you are going slow, put your flashers on. FIX THAT HEADLIGHT NOW, and find a different company to work for!
    Hitman, KiLLaZiLLa93, imup4it and 19 others Thank this.
  9. bzinger
    16,635
    66,094
    Dec 10, 2014
    omaha , ne
    [QUOTE="semi" retired;4402656]I thought the same thing. What is this world coming to? 1st, I don't mean any disrespect, but changing a headlight bulb has to be 1 of easiest things to do on a truck. Generally, you open the hood, behind the headlight, you'll see a plug with wires going to the bulb, take the plug off, there should be a ring you unscrew, and the bulb will come out. When you put the new bulb in, don't touch the bulb, use a clean rag or new vinyl glove, as the oil from your fingers will cause the bulb to get hot and burn out again. There should be a small notch in the base of the bulb, so it fits in the holder right, replace the ring, and plug the wire back on.
    As far as driving in the fog, I used to hate the fog, it's like driving with your eyes closed. If you have a headlight out, that increases your chances of not seeing. Let the lunkheads speed by you, go as fast as you feel comfortable, and if you are going slow, put your flashers on. FIX THAT HEADLIGHT NOW, and find a different company to work for![/QUOTE]
    amen semi retired !
    FLATBED and "semi" retired Thank this.
  10. Balakov100
    3,938
    2,641
    May 10, 2012
    Temple, TX
    If it's just a bulb, I wouldn't expect the company to pay someone to fix it.
    If it's not a Bulb or Fuse or something they should be getting the truck someplace to get it fixed.
    I would not be driving the Truck like that for long in the dark/fog.
  11. 201
    12,666
    26,039
    Apr 16, 2014
    I know, not like years ago with sealed beam headlights, where the screws would always strip out, but still not that hard. I feel bad for TGB, something as simple as changing a bulb to me is unfamiliar to a new driver. But that's OK, TGB, that's something, I feel, should be covered in school. I always kept a spare with me, just in case. And that last line, "you'll learn and and drive faster in the fog". WHAT? Man, (or dear), who the heck are you working for?
    AfterShock and bzinger Thank this.
