Food Grade Versus Sheet and Plate 53' van
Discussion in 'Ask An Owner Operator' started by DSK333, Sep 26, 2018.
  1. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    Switching over to the Dark Side for the Winter so I'm shopping for a 53' van. Can't decide if I want a "food grade" or standard sheet and plate deal. I found a couple nice plywood walled trailers but I'm hesitant considering I run all load board freight and I'm worried I may lose some revenue due to the possibility of limited choices. Let's hear it, gentlemen. Food grade versus sheet and plate; which do you prefer?
    Oldironfan Thanks this.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Reefer is more versatile. Just get side chutes, or easy to remove chute.
    DSK333 Thanks this.
  4. DSK333
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    I did consider that route but after giving it some serious thought I have zero desire to ever pull a reefer nor deal with a cold storage facility. I've heard way too many horror stories. Definitely want to keep it strictly dry van.
  5. MysticHZ
    MysticHZ Road Train Member
    5,885
    5,695
    May 28, 2010
    Food grade ... For the reason you stated. It doesn't have to actually food to require a food grade trailer.
    DSK333 Thanks this.
  6. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I have Utility 4000DX with plated walls and logistics posts and wooden floor...pretty standard and haul food all the time.I down paid $3K and payments are $580 a month. Better than lease.
    I never heard that food grade trailer needed to have inside plywood walls. I think that "food grade" has more to to do with cleanness and good condition. Many food shippers also require swing doors, wood floor, non-translucent roof and of course that it is odorless and waterproof and there are no protruding objects from the floor or side walls.
    RubyEagle, Dave_in_AZ, stwik and 4 others Thank this.
  7. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    I don't know about that...There are really many dry van loads that would not be loaded on a reefer. For a general freight purpose (I mean freight not requiring refrigeration) a dry van is better imo. Reefers get loaded with a dry van freight but the selection is more limited.
  8. Midwest Trucker
    5,911
    21,378
    Aug 31, 2018
    Tall Joe nailed it.
    I’d be surprised if a food grade shipper would prefer wood over plate. All my trailers are just like Joes only Wabash. We haul food grade all the time. The wood sides are a pain in the rear. I have skylights in mine which are helpful to see the freight and clean out debris. Metal roof a must. Get a tire inflation system too.
    Rideandrepair and DSK333 Thank this.
  9. DUNE-T
    DUNE-T Road Train Member
    6,977
    16,930
    May 10, 2015
    Detroit, MI
    Food grade just means you can haul food in it. If your trailer smells, has holes or whatever, it might be ok for some metal, recycling, e.t.c, but not for hauling food.
    The best to get would be plated and much younger than 10 years old, so you can haul autoparts in it
  10. DSK333
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    I was under the impression "food grade" was also a non-plywood lined van like a Duraplate. Whatever I get will have to be older than 10 years for now. Maybe next year if I like dry van enough I'll upgrade.
    Rideandrepair Thanks this.
  11. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    the fins on the floor help the air flow better although if your only hauling chilled its not such a big deal specially in the winter when temps will be much cooler anyway. For frozen you can't be cutting corners you'll need the best flowing fridge van ( reefer) you will see this when the shipper gets you to sit at the yard waiting for the temp to get down to 0 F
