For the In-Cab, am I supposed to start with the truck off?
Discussion in 'Questions From New Drivers' started by NY2001, May 23, 2022.
  1. NY2001
    NY2001 Light Load Member
    65
    56
    Sep 22, 2019
    I plan to begin by mentioning the fire extinguisher, three triangles, and seat belt. Then I plan to turn the truck on with the engine on to see the lights come off, read the gauges, then move on to mirror, windshield, wipers, horn, and then heater and frost. Finally, mention the steering wheel doesn’t move more than 10 inches and begin with the air leaks test. (I know how to do the rest).
    Is this correct or did I make a mistake here? I am told you have to, after mentioning the seat belt, extinguisher, and triangles, shift to on without the engine running, to wait for the gauges to go off, and then turn it fully on. But is this incorrect?
  3. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    Are you in school? If you are how did they teach you to do it??
    personally i would do my full in cab, then turn the key to check the gauge sweep, abs lights, & parking brake light indicator. Then start the truck.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,731
    18,550
    Nov 1, 2010
    Burnsville, MN
    The steering wheel doesn't move more than 10 inches?
    Bean Jr. Thanks this.
  5. tscottme
    tscottme Road Train Member
    Yes. You begin the in-cab pre-trip inspection with the truck turned off.
  6. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    Understand your confusion. But, it is kind of logical to start the pretrip with the engine off. When you step into the truck, the engine will be off. When you think about it, it does make sense to start the in-cab pretrip with the engine off because it already will be.
  7. NY2001
    65
    56
    Sep 22, 2019
    I meant degrees, sorry.
    Moosetek13 Thanks this.
