Well it is that time of the year, and have some questions. I really do not want to go out and purchase new chains, so wondering, if can get some used ones at one of the terminals. From as much as I remember, 2 sets of doubles and 2 singles are all that is needed, or 6 singles. For as little as I head out that way, can not see spending about $600 for something that I will not be using, just to carry around the extra weight.
I think that cables are still legal. Anyone have some input here.
Everyone be safe out there.
For the L/O, Chains vs Cables
Discussion in 'Swift' started by blsqueak, Aug 28, 2011.
Page 1 of 3
If you cannot buy them from Swift...check this out: http://www.tirechain.com/TRUCK-SUV-CHAINS.HTM -
Uh ... I only paid $45 for a new set of doubles last year. Comes out of the maintenance account.
First...you want to get a chain rack installed on your rig....much easier to get to and put away the chains after the first use. The correct amount of chains to have with you would be 4 bags of singles....(8 chains)....1 or 2 packages of bungee cords.
The doubles are a pain and heavy when applying, also the best way to apply doubles is to drop the trailer and get them on with the clearance away from the trailer....less stress on the back.....And pulling for Swift, the "extra weight" the chains add should not be a problem...
Whoever told you $600.00 for a complete set of chains is nuts....cut that price in half...and get your chains and rack from Swift, it will be deducted from maintenance account or you can arrange a payment plan of 3 separate payments.
Now the next obvious question is....do you know how to put the chains on correctly? and...do you know the difference between;
1. Minimum chain
2. Modified Maximum chain
3. Maximum chain
4. What chain minimums are for each State.....they are a little different.
5. Will you be required to apply a "drag chain"? Do you know what that is? -
educate us -
inkeper Thanks this.
I only got cables to be legal, I got them thru roehl brand new 4 bags of singles for 125 bucks. If you actually plan on using them go with chains no matter how much more they cost. The chain rack is a blessing too.
otherhalftw Thanks this. -
I forgot to mention....when using cables, check on the restrictions for each State...CA requires Maximum application of cables:
1. One each side forward drive outside
2. Cable on each rear drive axle tire (4)
3. Drag chain (cable) either forward of rear tandem (1 each side, and can be staggered)
Keep in mind...cables do not stand up well on dry/wet pavement...lose one on any required tire, and you are in violation. -
Page 1 of 3
