Forced dispatch
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by RichDoh64, Apr 10, 2017.
  1. RichDoh64
    RichDoh64 Bobtail Member
    7
    7
    Apr 10, 2017
    What are some companies that don't do forced dispatch?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    You would be inclined to understand that a dispatcher has the power to dispatch a load onto you. Once that is settled, you will be given loads you cannot refuse lol.
    RichDoh64 and sealevel Thank this.
  4. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Quite a few, but start turning down loads and you won't be seen as a profitable employee.
    x1Heavy and RichDoh64 Thank this.
  5. RichDoh64
    7
    7
    Apr 10, 2017
    I liked the system Crete Carriers used. Thet gave drivers a choice of loads and the driver picked the one that best fit their hours. Instead if forced dispatch companies that demand you deliver unrealistic appointment's in time.
  6. Florida Playboy
    Florida Playboy Road Train Member
    4,102
    6,621
    Dec 19, 2012
    Florida
    I believe Knight offered a choice of loads but now with the Swift merger who know if that's still the case.
  7. Allow Me.
    10,670
    12,210
    May 28, 2009
    Rancho Mirage, Ca.
    True "non-forced dispatch" co.are O/O co.s. Some co.s using co drivers might say, No forced dispatch, but they're just funnin' you. Dispatchers have more to do than trying to "shop" a load to see who will take it.
  8. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    Good luck with that. If they have loads to cover and you have hours, you're going to work. Company I work for typically lets me pick between a couple or 3 but at times there is no option as I'm needed so I get the load, like it or not
    RichDoh64 Thanks this.
  9. EatYourVeggies
    EatYourVeggies Light Load Member
    233
    327
    Nov 10, 2016
    If you plan on working for a mega bottom feeder, a mom & pop, or anything in between, it's forced dispatch. A truck that's sitting isn't turning a profit - simple as that.
    As others have stated, if you have the hours and your truck isn't in the shop, you will be expected to take the load.
    Now, maybe you can play the non-forced card but your dispatcher and planner will remember. Keep it up and they'll starve you out.
    In this business, you absolutely must take the occasional lousy runs to receive the good ones. Even O/Os must take a low-paying job if it means they'll be positioned to get home or get something much better.
    I do like the model which gives the drivers a choice between several runs. But there will be days when you basically have to pick your poison.
    RichDoh64 and x1Heavy Thank this.
  10. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    We did not fool with systems here. Dispatcher says here three cities, which would you like? A fast exam of the weather in my head usually gets me to a sunshiny
  11. RichDoh64
    7
    7
    Apr 10, 2017
    Wish I stayed at Crete. Best company out of eight that I have worked for.
    x1Heavy Thanks this.
