Forgot to cage the brake.....
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nikmirbre, Oct 8, 2020.
  1. nikmirbre
    nikmirbre Road Train Member
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    In order to get new slack adjuster on do I just have the wife step on the brake or something?
    Trucker61016 Thanks this.
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Release the air brakes(push the yellow value in) and pull the C clip off the side, and the pin out the brake chamber clevis. Slide it off and put it back on. Put something between the wheel to keep it from running over you.
    lwlevens, Rideandrepair and tj379 Thank this.
  4. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
  5. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
  6. Final Drive
    1,573
    2,505
    Jan 21, 2015
  7. AModelCat
    161,631
    I'm confused. Very confused.
    What does caging the brake have to do with changing a slack adjuster? Chock the wheels on level ground so she don't roll, release the brakes, install the slack adjuster, turn the adjuster nut on the slack adjuster to get it lined up in the clevis, install the pins and adjust the brake.
  8. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    I guess I meant that I took the other slack adjuster off and when I took the clevis pin out the rod of the brake chamber shot forward. In order to get the new one on, the rod of the brake chamber has to be back where it was ....
    Rideandrepair Thanks this.
  9. AModelCat
    161,631
    Ok. Chock wheels so the truck won't roll away and release the brakes. Easy peasy.
  10. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    Ill take some pictures tomorrow. It looks easier on YouTube LOL.
    skellr and Rideandrepair Thank this.
  11. nikmirbre
    5,554
    10,210
    Jul 27, 2011
    High Point NC
    They were released when it shot forward.......
