Frame Rust
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BCO532335, Nov 7, 2015.
Page 1 of 3
How old is this truck?
More background info needed. Is it yours? Did you just buy it, or looking to buy? If it's yours...why did you wait so long to address this issue???
Wow mines been in the salt for 13 years and doesn't look that bad.
I assume this isn't a crossmember? -
I guess that's marginal for a truck that old. I've driven lots of trucks with rusty frames, and never had one break, not to say, it won't happen. I've taken 5th wheels off, only to find, half the frame thickness was gone. If you are going around a corner with a heavy load, and hear a snap, you'll know what it was. ( seen it happen)
Straight Stacks Thanks this. -
At a minimum you should knock all that scale off because it just holds water. Just the bare solid steel will last longer than being covered with scale.
Break out the chisel, needle scaler, pop a top and go to town. -
I've owned her for 8 years. I had the frame sanded and painted 4 years ago. Today I had it power washed and that's when I noticed it under the cat walk.
Page 1 of 3
