Is anyone running a freezer in your truck? If you are what brand and model are you running and also 12 or 110 volt.
If 110 are you running a separate inverter for the freezer?
Freezer?
Discussion in 'Ask An Owner Operator' started by earnies2, Jan 26, 2020.
Whynter. Dometic
Dometic
ᐅ Outdoor Electric Coolers – Compact, Portable, Durable | Dometic
I have the CFX3 35, runs on 12 V or 110 V.earnies2 Thanks this. -
I use a 1.7 Galanz fridge(walmart $79) as a freezer. It is turned to the coldest setting. 110 v. Running on the same inverter that I use for everything else. I've had it for 1 1/2 years without any problems.
I seal and freeze my food really well before bringing to the truck. (At least 2 days in my home freezer) -
Whatever came stock with the truck.
JDJenn72 Thanks this. -
I am OTR out 6 - 8 weeks. When I had my Volvo I had the Galanz 3.2 fridge as a fridge and the Galanz 1.7 as my freezer. That set up worked awesome. Had home cooked meals every day.
Now that I have 2020 Cascadia that came with a fridge, my Galanz 1.7 sits on it and it fits perfectly. (Where the TV is suppose to go) -
Almost any of the modern 12v fridges can be used as freezers. There are lots and lots of brands now. I have owned about 5 or more Truckfridges in different RVs, trailers and my rig.
Truckfridge.com
Also, Whynter and Dometic as noted above plus...
Vitrifrigo
IndelB
Isotherm
Engel
ARB
National Luna
The list goes on. They are really popular nowadays.PE_T Thanks this. -
I run a freeezer , its called the aluminum trailer storage box and drive in weather colder than 30.
I’ve had a dorm size fridge with separate freezer section for many years. 110v, and of course you need an inverter.
