Freighliner Run Smart Predictive Cruise™
Discussion in 'Questions To Truckers From The General Public' started by Bub10294, Jul 9, 2023.
  1. Bub10294
    Bub10294 Bobtail Member
    So I have a 2024 Freightliner cascadia and my company has this run smart tech on it.. I’ll be driving perfectly normal on cruise speed and the truck will just drop me down to pedal speed because of road conditions 1 or 2 miles ahead like for a hill, mountain. Etc. it’s meant to save fuel but it cuts my speed down at the most inconvenient times. Does anyone know how to turn this off? Google says it’s an antenna connected to a control box but I can’t seem to find it and if you remove the antenna I’m assuming that will disable the tech temporarily.
  3. Siinman
    Siinman Road Train Member
    5,451
    14,023
    Mar 5, 2017
    Kansas City, MO.
    It is a program in the ECU. So if you mess with it they will find out. Not your truck to go and mess around with it. Have a problem with it go to the company and complain, If that is not good enough go find a different job. No need to tare someone else's stuff up because you do not like it.
    wichris, tscottme, dunchues and 2 others Thank this.
  4. Blagoje
    Blagoje Medium Load Member
    441
    960
    Jul 14, 2022
    Paris, Illinois
    I have experienced this as well and other late model Cascadias and it is so unbelievably obnoxious that I asked my company (Roehl) to turn it off but they refused. Most commonly I would be going up a hill and it would just shift into E-Coast and I would begin slowing down rapidly when I needed to be speeding up. Happened every day and there was no shortage of times where I felt unsafe because of this feature.
    hope not dumb twucker and ducnut Thank this.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    Shouldn’t be using cruise to pull a mountain
    Numb Thanks this.
  6. ducnut
    ducnut Road Train Member
    2,587
    7,807
    Dec 31, 2010
    SPI
    Some of the new technologies suck.
    tscottme and Blagoje Thank this.
  7. tscottme
    tscottme Road Train Member
    Messing with safety features can get you fired on the first attempt at the companies I worked for.
    Siinman Thanks this.
  8. tscottme
    If you floor the "gas pesdal" it will usually override that speed decrease up until the following distance triggers emergency breaking.
    Siinman and hope not dumb twucker Thank this.
  9. Magoo1968
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    Sounds like another one of those dumb companies that give more speed on the cruise .. he was saying it dropped to pedal speed so I assume it’s set up that way ..
    hope not dumb twucker Thanks this.
  10. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    You might be able to change the drop speed in the eco menu to even the pedal. Our company actually tells us to do that but I ain't done it yet so not exactly sure how to
    Magoo1968 Thanks this.
