freightliner 07 a.c. code
Discussion in 'Freightliner Forum' started by truck6677, Apr 23, 2014.
  1. truck6677
    truck6677 Light Load Member
    83
    11
    Jul 21, 2012
    Hey guys I keep getting this code bad havc 146s010.on my truck.some tomes in need to wiggle the knobs on the control panel to make it come on any ideas
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    This is from memory, but I think SID10 is the blower motor circuit. There is more to that code that you're missing. It should give an FMI too. It's usually a bad blower motor or blower board. It will disable the blower motor if the current is too high, motor temp is too high or if the voltage isn't right, and set that code at the same time. If you turn it off and back on it tries again, but will shut it off again in the problem is still there.
