Freightliner 2012 cascadia Relay fuse box
Discussion in 'Ask An Owner Operator' started by MackRookie, Jul 16, 2018.
  1. MackRookie
    MackRookie Light Load Member
    193
    25
    Nov 30, 2017
    Canada
    Hey im having hard time reading the fuse box. Cant figure out which one is the left turn relay. My left turn blinker is going really fast on dash and is not blinking on left turn marker. Cant find which one is the relay i need to replace. When i turn 4 ways on its working. Any cascadia owner know which name its under? Last resort is taking each relay out at a time.
  3. me myself and I
    me myself and I Heavy Load Member
    733
    312
    Oct 5, 2009
    vernon hills,Il
    You did check that bulb?
    MackRookie Thanks this.
  4. MackRookie
    193
    25
    Nov 30, 2017
    Canada
    Thought the bulb is fine sinxe its working when i put 4 way flashers on
  5. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    Pull the relay out and shake it. If it rattles it's bad. The two relays are side by side. Cut your signal on you will be able to hear where it is.
  6. Fortunata
    Fortunata Bobtail Member
    Hello
    Is there anyone who can help I have a refridge in my 2017 freightliner cascadia and I was replacing the actual cigarette lighter housing and it sparked and I have replaced all the fuses and not sure what other step to take. Can anyone help!
