Freightliner battery setup
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bennett, Jan 14, 2011.
  1. Bennett
    Bennett Bobtail Member
    we have a 1992 Freightliner and are having starting issues with the batteries. Can anyone tell me which of the 4 batteries is the starter (or main) battery? Also, can anyone tell me how much a new battery costs?
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    All 4 will supply power to the starter.
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    Dont replace one, replace them all at the same time. Your old batteries will destroy a new replacement battery.
    bullhaulerswife Thanks this.
  5. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    What are the issues? It won't start after it sits overnight....?
    You could have a bad connection, broken or corroded wire, all sorts of things to look for.
  6. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    My 96 freightliner had 4 batteries and two hot leads from the batteries to the starter.I had one of the ends on one of the main leads break off once and it wanted to turn slow.Then i fixed the end.
  7. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    on my 97 dump freightliner 2 of my batt. was hook to the starter and the other 2 was hook to the acc. but i did buy a cable to hook them all together and replaced all..
  8. Cseal
    Cseal Bobtail Member
    12
    Oct 31, 2010
    tennessee
    Definitely replace the batteries as a set even if you only have one bad. Around here they run about $100 each.
  9. Bennett
    I appreciate all the input guys but here's the deal. We just bought the truck (it's a big dump for hauling asphalt) last week. When we bought it, it started right up. We had our diesel mechanic there to look at it. I drove it. We failed to actually look at the batteries at that time. When we picked it up the weather was cold (in the teens) and it wouldn't start. We tried jumping it with another smaller truck, didn't work. We finally decided that we would pull all 4 batteries, take them home and hook them up to the charger, warm them up and then see if it would start. When we pulled them that's when we noticed that 3 of the 4 batteries had green stickers on the side that said "BAD Battery". All of our money is tied up in the truck and fuel so $400 is hard to pull together right now. We thought we could try to replace 1 a week. Do you think it will work? We did replace one battery (it was $100) and the truck did start. We know we should replace them all together but we're just getting started with our own truck and didn't expect this right off the bat.
  10. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    the problem with not replacing all the bad batteries is that one could be shorted out. a shorted out battery will draw the rest down. if you can plug it in at night it should start off two batteries. but one shorted out battery will ruin the others.
  11. oneshot
    626
    248
    Feb 28, 2009
    mississippi
    Autozone will check each bat free.At least you'll know for sure which ones are bad and you should leave them off like FYDA said.
