Freightliner C2C Lt load Spec thoughts?
Discussion in 'Experienced Truckers' Advice' started by evofd, Sep 1, 2021.
  1. evofd
    evofd Bobtail Member
    14
    27
    Nov 11, 2011
    Anyone figure the ultimate truck spec for pulling <20k C2C loads on a new Freightliner? Your thoughts welcome.
    Thanks
  3. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,861
    Apr 29, 2020
    Aerodynamic and geared for fuel mileage. Gearing will depend on how fast/slow you plan on running. With that weight, 65-68 mph could get you close to 10 mpg with the proper setup. Every gallon of fuel you can save can add up to big money in your pocket! Good luck
  4. Ridgeline
    22,605
    120,050
    First the trailer is critical in this, you have to select it carefully and for the purpose of the freight you are going to haul. Then use any truck (class 7 or 8) with a smaller displacement and multiple gear transmission, geared to the lowest fuel consumption per manufacturer’s specs. A dealer (good one who is experienced in selling trucks not carpet) can give you several options for the driveline and with fuel consumption targets.
    baha Thanks this.
