i just got a new cab level that controls the air bag and ride, the instruction are no good looks like they got wet or something...anyway can someone tell me just how to set this thing???? i have tried a few times and it always go back down or to high..thanks
freightliner cab level
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Apr 10, 2012.
You leave the rod unattached and then move the arm of the valve so bags fill with air until you reach the correct ride height for your model measured where f-liner says, once at the correct height move the arm to the neutral spot and attach the rod that goes to the frame. You will likely have to adjust the rod length. Do not move the arm from the neutral spot. Some valves come with a golf tee to stick in the holes that hold the arm in neutral.
I assume the lines are hooked up right! -
yes lines are hooked up right..i will try to find the right height then go from there.. thanks
LOLs dump your air bags if you have your significant other in there with you. the bouncing will mess it up.
