Freightliner Casacadia tank haulage
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Langlois67, May 15, 2020.
  1. Langlois67
    Langlois67 Bobtail Member
    Hello
    I am willing to become a broker on 2 axles tank trailer to haul chemical. I am looking for a 2015-2016 Freightliner Cascadia but I wonder if a DD13 engine with 470 HP, 13 manual speed could be appropriate. If not, what specs must be appropriate please?
    Thanks a lot
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    What rears. Where you going to run?
  4. RockinChair
    RockinChair Road Train Member
    5,099
    12,860
    Feb 19, 2012
    CC, TX
    Fifth wheel height will be a very important factor in proper weight distribution. If you're planning on leasing on to a company, find out what fifth wheel height they need for their trailers.
    In general, a Cascadia with a 470 HP engine and a 13 speed sounds great. You will probably need a pump and/or an air compressor; these will be driven by a PTO on the input side of the transmission.
    baha Thanks this.
  5. whatd
    whatd Bobtail Member
    27
    24
    Apr 18, 2015
    I'd add that you can also run an air line off your truck compressor, which would be the least expensive option. I put a Quincy compressor on my pto for about $2500.
  6. ChicagoJohn
    ChicagoJohn Road Train Member
    2,387
    2,749
    Jan 14, 2016
    Chicago
    Unless the truck is specked with larger compressor, he’d want to use a separate compressor. A large compressor for the DD13/15 runs about $3800
