Freightliner Cascadia 2013 DD 15 Diesel in coolant reservoir!
Discussion in 'Freightliner Forum' started by Rollerr, Sep 9, 2018.
  1. Rollerr
    Rollerr Bobtail Member
    4
    Freightliner Cascadia 2013 DD 15.
    I noticed there is diesel on top of coolant reservoir. But the truck is running in normal temperature.
    Any ideas are appreciated.
    Thanks.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    You have a injector cup leak I would think.
    mhyn, Rollerr, Rideandrepair and 3 others Thank this.
  4. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Yep injector cups
    Edit: itll run normal but fix it as soon as you can.
    One of my trucks as of two days ago is mixing diesel into the oil.
    Prior to that my other truck had the same issue as yours
    Rollerr and Rideandrepair Thank this.
  5. Oldironfan
    5,777
    5,543
    May 22, 2017
    Diesel in oil is usually a head issue, or liner issue.
    Or injector over fuel, fuel dilution issue.
  6. Oldironfan
    5,777
    5,543
    May 22, 2017
    Don't quote me I'm just a dumb driver.
    Rollerr and peterbilt_2005 Thank this.
  7. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    We still appreciate you guys its a lifestyle that gets in your blood
    Rollerr and Oldironfan Thank this.
  8. AModelCat
    159,126
    Might wanna get that issue rectified quickly. Petroleum products will deteriorate heater and rad hoses.
    Rollerr and d281833 Thank this.
  9. Rideandrepair
    17,337
    56,256
    Aug 8, 2015
    Hopefully you can change them W/O pulling head
    Rollerr Thanks this.
  10. Antinomian
    Antinomian Road Train Member
    2,112
    3,333
    Feb 17, 2013
    Bad injector cup.
    You need to park it ASAP. Fuel in the coolant can cause hoses to blow when the fuel gets hot and starts to expand. Also, you may have coolant in your fuel tank. That too is common with an injector cup leak.
