Freightliner Cascadia rear suspension ride height
Discussion in 'Freightliner Forum' started by istumped, May 20, 2017.
  1. istumped
    istumped Medium Load Member
    494
    234
    Feb 8, 2015
    I replaced the rear suspension leveling valve on a 2014 cascadia can't find what the ride height suppose to be. And where to measure from. Should I measure from the ground to the bottom of the frame. Or between the suspension stops. Needing help thanks
    Ajadgill Thanks this.
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Find another cascadia and measure it.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Not being a ######## but, you should call Freightliner to make sure you get the correct height.
  5. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    I've always thought top of rear axle tires should be level with top of the frame
  6. istumped
    494
    234
    Feb 8, 2015
    Brilliant idea. If their where some around I may do that. Like I havent thought of that
  7. istumped
    494
    234
    Feb 8, 2015
    I would call if they where open.
  8. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    Never called them, not sure if they can answer that question.
  9. Transtar4070B
    Transtar4070B Bobtail Member
    12
    7
    Oct 13, 2011
    2-5/8" between the axle stop on the frame and the top of the ubolt.
    driverdriver Thanks this.
  10. driverdriver
    4,254
    5,282
    May 30, 2011
    There are several locations that are 24/7
  11. Animosus
    Animosus Heavy Load Member
    710
    2,798
    Dec 7, 2015
    SE Wyoming
    I'm assuming you have an AirLiner suspension.
    [​IMG] [​IMG]
