Freightliner Cascadia shaking after steer wheel hub assembly replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ljesko13, Jun 2, 2025.
  1. ljesko13
    ljesko13 Bobtail Member
    39
    23
    Aug 30, 2021
    Hi all, any ideas on what would cause this? Here’s the full backstory:
    Had a leaking wheel seal, decided to just replace it myself. Once I took the old hub off, replaced the seal and torqued it back to 300lbs (steer axle, Conmet hub part #10082204) I couldn’t freely move the hub until I mounted the hub cap back on and lubricated it. Even after that it was hard to move but I figured that’s how it is. Once I started driving as soon as I passed 60mph truck would start shaking. Since I’m on the road and not at home I thought it might be bad wheel bearings, so I just bought a whole hub (preset with everything) and replaced it, but same deal - once I torqued it I can’t m
