Freightliner century 07- no datalink
Discussion in 'Freightliner Forum' started by Singhfreightliner07, Apr 8, 2017.
  1. Singhfreightliner07
    Singhfreightliner07 Bobtail Member
    6
    Apr 8, 2017
    hello guys, posting here for the first time and hoping my long standing problem will be solved. I get this message 'no datalink' on my century 07 dashboard. As a result, all the guages except for the air pressure stays at mark zero. I read different forums and posts amd tried most of the methods but to no avail. This error popped about a year and half ago and comes up once in a while and goes away just like that.
    Today I disconnected the cable which goes under the cab to the connector which i assume is
    to the panel behind the seat on driver's side. All guages came up. I reconnected it and same problem occurs. Along with this gauge problems my radio, ac and none of the cab lights work.
    Thanks in advance. Hope to hear any suggestion/advice soon.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    After you follow the procedure on that excellent post above, let us know if your ABS module is mounted on frame under 5th wheel or in B pillar next to driver seat. I am guessing under 5th wheel.
  4. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    Care to elborate on this???
  5. Animosus
    Animosus Heavy Load Member
    711
    2,800
    Dec 7, 2015
    SE Wyoming
    Your ABS ECU will be mounted in the B-pillar. Your ABS modulator valves will be under the 5th wheel.
    Smokie9200 Thanks this.
