Freightliner century . Is it hard to changing the air compressor?
Discussion in 'Ask An Owner Operator' started by henboy1, Aug 23, 2018.
  1. henboy1
    henboy1 Medium Load Member
    331
    139
    Mar 26, 2011
    stockbridge
    Detroit 12.7 . I'm hearing this screeching /chattering noise right before it purges .After it purges the noise stops , so I know it's the compressor.
    Is there a trick to changing the air compressor on these older Detroit? I know get into the back with an extension will be tough . Will I need a strap to hold a heavy compressor before I take all the bolts off?
    I have done starter, AC, alternator but not the air compressor.
    Dave_in_AZ Thanks this.
  3. UturnGirl
    UturnGirl Road Train Member
    3,081
    13,456
    Jan 16, 2010
    Texas
    It should be right up front there. A couple bolts and voila. Mine went out once and I walked to a truck parts store got the part for $20 and a driver changed it out for me in under 15 minutes.
  4. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Huh? $20 for the Air compressor? This is is about a $650 part with the core . I am not talking about the governor. I can easily change that
    Bean Jr. Thanks this.
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Yeah, he's thinking governor. I changed mine on a cat. They are pretty simple to do. I used a strap just to keep it from falling. Left it hooked up and used it to hold the new one while I muscled it in to place as well. Just easier, I think.
    Tug Toy Thanks this.
  6. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Great response . Almost like the #### starter with a strap . The gears was easy to mesh from the starter to the flwy wheel, why i recently changed the starter .Is this compressor gear easy to mesh with the compressor gear .? I mean, will I have to force it in to meet the other gear ? I hope I explained it right
  7. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    Dang that’s cheap,, almost $1500 for the one on my Volvo d13 from the sltealership... that doesn’t include labor
  8. AModelCat
    160,846
    You sure its the compressor and not the unloader chattering a bit before it unloads? Hate to see someone spend big bucks without at least seeing if there's a cheaper fix.
  9. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Where is the unloader located?
    The compressor is also leaking a lot of oil from the bottom
  10. UturnGirl
    3,081
    13,456
    Jan 16, 2010
    Texas
    Ugh..sorry...
  11. RustyBolt
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    No need to force it. Just turn it til the gears line up. Slide it the rest of the way in and turn it to line up the bolt holes. Easy really.
