Hey everyone suddenly my freightliner has a short somewhere. I took the batteries out and took it to the battery shop they said my batteries were good after they charged them up. I put the batteries on the truck and right when i try to connect the last terminal it sparks huge and smokes from the terminal/battery connector. I dont know what the issue could be but something is eating up the batteries right when i connect it to the truck. Could id be my alternator or something?
Freightliner Century problem with batteries
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by gtilogistics, Sep 15, 2017.
thaistick and Dave_in_AZ Thank this.
Confirm you're connecting the cables correctly. Then check for anything on the positive side touching the frame or any metal. Check for rubbed cables.
thaistick Thanks this. -
The starter could have an internal short.I had kind of similar problem too like when I turned my ignation on the starter would short and get stuck like that making a noise and it would get the thick neutral battery cable really hot.
I changed the batteries and when i connect the main red power to the batteries, it will drain the batteries while the truck is off & the red wire is really hot when you touch it. If the truck is off and the red is disconnected it wont drain the batteries
You have a short to ground, that is probably unfused. Something in your positive side has a path back to the negative side.
I agree. Check your big stuff. Maybe the hot starter cable is chafed to frame possibly or some other flaw allowing the gremlins of electricity to flow at the volume you feel heat.
That's not a good thing. Those batteries need to be able to sleep, not feeding anything when truck is off. -
Feel electrical items for heat or shoot them with an IR temp gun. Its literally possible for the whole cab or starter body etc etc to be acting as a resistive heat element.
You can pull fuses and relays one at a time and amp probe across the blades, or have someone watching battery volts for a rise, or even spark check the terminals each time you pull a new one (kinda crude way though)
Be sure your negative battery post shares a zero volt reference and continuity with all your major iron. Frame, cab, block, ground lugs etc. A testlight can help in a bind.. You want full glow or none.. A faint glow is pointing you in the right direction. Just snoop until you find something. Better your meter skills the faster youll get there.
